Garyt350z Posted November 12, 2014 Share Posted November 12, 2014 What all do I need if I want to increase my steering angle? I have found tein tie rods and ends, but it says they won't change the angle, only support a more aggressive angle! :s but how do I get that?lol Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted November 12, 2014 Share Posted November 12, 2014 with about £800 worth of steering products from the US OR about £1000 from Driftworks in December Quote Link to comment Share on other sites More sharing options...
StevoD Posted November 12, 2014 Share Posted November 12, 2014 And a @*!# load of grease if it's a road car Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted November 12, 2014 Share Posted November 12, 2014 You can achieve this cheaply by getting the Tein inner and outer tie rods and just cutting some lenght of the wheel stopper on the compression arm until you get to the maximum lock that does not cause interference. I've got TEIN tie rods but not cut the stopper yet as the angle I have is ok for grip driving on track but the drift guys accross the pond do this. 1 Quote Link to comment Share on other sites More sharing options...
Garyt350z Posted November 12, 2014 Author Share Posted November 12, 2014 Lol so costly for all the use it would get then? Defo considering the tein rods tho. And when u chat about wheel stopper on the compression are, do u mean the 2 wedge shaped rubber bushes that sit either side of the main bush and crush slieve? I have superpro ones installed btw Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted November 13, 2014 Share Posted November 13, 2014 Lol so costly for all the use it would get then? Defo considering the tein rods tho. And when u chat about wheel stopper on the compression are, do u mean the 2 wedge shaped rubber bushes that sit either side of the main bush and crush slieve? I have superpro ones installed btw Don't be daft! Take some time and look at your car to understand. Put the steering in full lock eg to the right. Go to the passenger side wheel and you can see the compresion arm and the stopper spur and if you look at the wheel hub you will see the stopper plate. The plate rests on the spur stopping the wheel from further lock. By shortening the spur you allow for further lock/increase in your steering angle. Depending on your front wheel and tyre combination you can cut up to or more than half of the spur without the wheel interfering with the arch or body. I recommend cutting bits off at a time. The spur can also screw out which can help you visualise how much to cut for max angle before interference if any. Obviously you have to do both sides currently and I reccommend cutting after you've installed the tie rod with the increase angle configuration. Herewith a pic of the of arm with the spur. 1 Quote Link to comment Share on other sites More sharing options...
Garyt350z Posted November 13, 2014 Author Share Posted November 13, 2014 Ah I see! Well explained lad i'l get the tie rods and end bought now first tho! Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted November 14, 2014 Share Posted November 14, 2014 We have the Tein ones in stock if interested Quote Link to comment Share on other sites More sharing options...
