Wasso Posted November 30, 2014 Author Share Posted November 30, 2014 Update from the weekend: Sanded down the gear surround to flatten out any imperfections. Re-sprayed with the high build primer and sanded once more for the final coat of high build. Sanded down the upper central dash. First off taking out the triple gauge hoods. A coat of high build, sand and a further coat of high build. Next few stages: Sand final high build with 1200 grit for a super smooth base. Fit the upper and lower dash into the car, inserting the ipad section between the upper and lower dash sections. Bond with 2 part epoxy glue, also glueing the join between the upper and lower dash. Leave to set, remove central dash and reinforce the joins. (From here the central dash becomes one unit. Fill gaps around the ipad mounting plate, and /or in any other areas. High build prime areas that will be painted. Drill holes into the iPad mount so that fixing the dash to its oem mounting points is possible. The iPad mount will have some suede behind the iPad itself, covering any mounting holes. Spray the entire dash gloss black. If this results in imperfections then I will probably go ahead with the Carbon Skinning. Ultimately I want a perfect finish. If the gloss works I'll be happy. Next weekend for further instalments 4 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 30, 2014 Share Posted November 30, 2014 Have you had a chance to test fit with AC controls and Haz button in place into the centre console, just to check if it doesn't clash with the white AC control box? Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 30, 2014 Author Share Posted November 30, 2014 (edited) Good call. Not yet, but there's a fair amount of room behind there. The White box sits far enough back so should clear. If anything doesn't clear or is touching I've got a dremel and I'll just go to town on the bits that get in my way I'm likely to encounter a problem or two, but will need to create some custom fixings to accommodate the change in layout. We shall soon see at the next stage Edited November 30, 2014 by Wasso Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 30, 2014 Share Posted November 30, 2014 I would hate to see so much effort in fabrication to be beaten by stuff interfering. I'm sure it will be fine tho. Hope the Haz button don't clash with the gearstick / gearshift motion Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 30, 2014 Author Share Posted November 30, 2014 Me too, but I've enjoyed it something I've never done before and learnt some skills along the way. The dials have come down about 4cm and the Hazard switch about 1cm. The hazard switch should be fine as there's the Alu surround that will be in place, which will also need some fine tuning. There's always a way to fix these things, a dremel and a hammer! If anything I'm more worried about making the two central pieces into one. Some serious bonding and reinforcement required. I've got some ABS plastic on hand to heat and melt to form greater strength inside of the central section. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted November 30, 2014 Share Posted November 30, 2014 Looking great, I quite like it in that primer colour too! 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 30, 2014 Author Share Posted November 30, 2014 Looking great, I quite like it in that primer colour too! I thought that too 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 6, 2014 Author Share Posted December 6, 2014 Good day to you all..... Today was the inaugural moment to test fit the dash!! Took out the stereo, and all heater controls and fitted to the new custom made dash. Fitment is pretty good. I've got a bit of work to do with the heater control box, as it's now rubbing on some plastic stability parts inside the dash. Shouldn't cause a problem as it's only for internal rigidity which isn't needed with the iPad dash. Here is the dash without the iPad installed. Then testing the iPad holder in it's location, which hasn't been cut to size or modified and it's not far from being perfect. Then with the iPad on, just for the effect. Next stage is to adjust the areas inside the dash which are rubbing against heater controls. The white box behind is miles away from the controls which I'm really pleased about. Then rub down the area in which the iPad holder will reside ready for fitment. Once fitted it will be bonded in place, as well as the upper and lower dash, which will be bonded to make one unit. I've checked the two screws which hold the middle of the dash to the car, and they are hidden behind the iPad holder, which was planned. So I'll drill two holes in the holder for access to securing the dash to the car. Then, reinforce the dash now that it's a single unit. Next stage is to fine tune the holder in the dash, with filler, sanding, priming and then painting. 4 Quote Link to comment Share on other sites More sharing options...
HoundDog Posted December 6, 2014 Share Posted December 6, 2014 All this hard graft to listen to the likes of Buck's Fizz Barry Manilow to name a few on your music collection. When u got that v8 you won't want to listen to the chessy tunes lol. Fantastic work Ian and thanks for sharing. 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted December 6, 2014 Share Posted December 6, 2014 Looking good mate 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 6, 2014 Author Share Posted December 6, 2014 Well, it's multipurpose. Music (Digital) Videos (whilst stopped of course) SatNav with live traffic Dash Command for engine monitoring etc Telephone Handsfree (ios8 update connects to your iPhone) Additional benefits Email Angry Birds Holiday photos Dirty movies Text Whatsapp To be fair the V8 will have two modes. Chill out cruise and all out fun. For the times I'm chilling I've got all the luxuries and more whilst arm on door and cruising along. Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 6, 2014 Share Posted December 6, 2014 Good job Ian 2 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 6, 2014 Author Share Posted December 6, 2014 Good job Ian Cheers Mr G Quote Link to comment Share on other sites More sharing options...
GMballistic Posted December 6, 2014 Share Posted December 6, 2014 Great work so far, ...can't wait to see it all finished up as I'm sure it's going to look great. Quote Link to comment Share on other sites More sharing options...
Daryl Posted December 6, 2014 Share Posted December 6, 2014 Top job mate, looks stunning! 1 Quote Link to comment Share on other sites More sharing options...
Neilp Posted December 6, 2014 Share Posted December 6, 2014 Looks outstanding. Should maybe offer it to a mould before fitting? Could be potential money maker there! 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted December 6, 2014 Share Posted December 6, 2014 Looks outstanding. Should maybe offer it to a mould before fitting? Could be potential money maker there! This is a good idea - I think my centre console would look nice with an iPad too 2 Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 6, 2014 Share Posted December 6, 2014 Looks outstanding. Should maybe offer it to a mould before fitting? Could be potential money maker there! Knowing Wasso Industries, he's already thought of that 2 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 7, 2014 Author Share Posted December 7, 2014 Well, it would be something worth getting involved with, but Soundman in the US has a patent pending on the design I believe. Not sure if that would cause ossues in producing a ipad kit. Secondly as Apple change their designs so often I'd not be able to keep up. The cost to create a mould and be able to move with the Apple changes would cost a fair amount to keep going with it. If I had more time I'd go for it. Spacers and projects take up the majority of my spare time. Update later today hopefully of the ipad fitted and bonded 1 Quote Link to comment Share on other sites More sharing options...
andy james Posted December 7, 2014 Share Posted December 7, 2014 Wow! That is going to look soo good when it's done especially in the dark! Great work. 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 7, 2014 Author Share Posted December 7, 2014 Cheers Andy, it's getting close now. Tricky stages ahead now that will affect the final finish, so I need to take additional care to make sure it's a one time fit. Making repairs at this stage will be difficult. Quote Link to comment Share on other sites More sharing options...
Keyser Posted December 7, 2014 Share Posted December 7, 2014 Just caught up on this - looking good mate If you give it a coat of bright Green paint it will look nearly as good as the dash I did 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 7, 2014 Author Share Posted December 7, 2014 Just caught up on this - looking good mate If you give it a coat of bright Green paint it will look nearly as good as the dash I did Cheers Chris, getting there Remember Blue and Green should never be seen! Quote Link to comment Share on other sites More sharing options...
buster Posted December 7, 2014 Share Posted December 7, 2014 awesome work m8 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 7, 2014 Author Share Posted December 7, 2014 awesome work m8 Cheers Bob Sunday Update: None apart from I glued the upper and lower sections together and the bond/dry time is 12hrs. So that's the end of that for today lol. Tomorrow I'll update more........ Working from home Quote Link to comment Share on other sites More sharing options...
