Crunching between 4th and 6th
Jalada
I've managed to consistently replicate some crunching between 4th and 6th gear when accelerating; doesn't happen between 5th and 6th. Looking around on the forum this seems to be a common problem.
The only thing is my car is now out of warranty; is this going to be expensive to fix (I expect the answer might be yes...)? And does anyone have advice or recommendations as to whether I should go to my local Nissan garage (Glyn Hopkin, Milton Keynes) or someone independent? If so; recommendations are much appreciated, I don't know anywhere. Car has only been serviced at main dealerships.
Any advice appreciated :)
Edited by Jalada
  • 2 months later...
My car has been with Japex for a week now after an initial gearbox oil change didn't help. Having sent the gearbox to their local specialist, the conclusion is 2nd, 4th and 6th synchromeshes are all worn. Because of the time and labour to have the gearbox out, and because I've said I'm more concerned about doing things properly than cutting corners, they are advising to replace all 6 synchromeshes at an approximate cost of £1500 including labour.
Feels about right and I've said to go ahead (pending parts delivery). The car has only 28000 miles on the clock (2010 reg) so it's a bit puzzling, and obviously my primary concern is I spend this money and time getting it fixed and it just happens again one day.
Thoughts and advice appreciated.
Sounds pretty fair for the work being carried out but `i would have eliminated the cheaper options first, slave cylinder, clutch, release bearing & the little alignment bracket below the gear knob. All of which would have cost a max of £400 before re-building a gearbox where you should be asking yourself if the above parts are worth changing whilst the box is out
  • 1 month later...
It's been a long time away (over a month) but today I finally got my car back, and so far it is crunch free.
I opted to have all the syncros replaced, as per my previous post. Unfortunately the work was held up because (and this might be useful to some) Nissan have changed 5th and 6th gear since my car came out of the factory and the syncros did not fit the gearbox. 5th and 6th gear also had to be replaced. They kept quiet about it when the parts were ordered and it was (apparently) not indicated on the information about the syncros.
If this is true (and I have no reason to believe it isn't), it feels like Nissan are partly responsible for all this, because it sounds like they know there is a problem. Does anyone have any advice, or think it's worth contacting Nissan to argue about?
That said, it is OK now, and Japex looked after me and my car :) and the most important thing to me is having it back.
I guess in hindsight if I'd just had 3 out of 6 syncros replaced I perhaps would've only needed one gear replaced? But perhaps not, I'm not an expert. Oh well, it's only money.
