leet8845 Posted November 9, 2014 Share Posted November 9, 2014 There always seems to be a twist in my seatbelt, i tried removing the bolt at the bottom and untwisting it but it seems to be on backwards because I cant reattach it and remove the twist. The passenger side seems to be the same. Is this a 'feature' of the Z? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted November 9, 2014 Share Posted November 9, 2014 Ask YouTube how to untwist it ... it's dead easy ! Quote Link to comment Share on other sites More sharing options...
leet8845 Posted November 9, 2014 Author Share Posted November 9, 2014 I couldnt find a Z specfic video, is this the fix you mean't? Quote Link to comment Share on other sites More sharing options...
leet8845 Posted November 9, 2014 Author Share Posted November 9, 2014 There is no way I can twist the belt inside the thin slot of the buckle. It's only wide enough for the belt, no room to twist. I could drill a small hole in the end of the slot and twist it in this. I think I may do so, do you think a tiny hole at the end of the slot will effect it's strength? Quote Link to comment Share on other sites More sharing options...
leet8845 Posted November 9, 2014 Author Share Posted November 9, 2014 So I drilled a hole in the seatbelt slot of the clip to make it a but wider, then twisted the buckle round the right way. There was still a twist the bottom half of the belt....I think it must have been designed to have a twist in it ....so I unbolted the bottom and turned it round and bolted it back in (the wrong way) but it's very secure and wont go anywhere, just not as flush due to shape of the clip but I covered with the rubber cover. At least there's no twists now. Just a normal seatbelt like other cars Quote Link to comment Share on other sites More sharing options...
kano Posted November 11, 2014 Share Posted November 11, 2014 I had this. All I did was turn the belt in the plastic hanger thing at the top of the belt near your shoulder. It'd been the wrong way round for years, since I got the car. Quote Link to comment Share on other sites More sharing options...
