350Z sat-nav problems
David Booth
Evening all!
The sat nav on my 2008 350Z has never been brilliant (slow to compute and ages to programme directions in), but now it won't even give me a map display.
I have the original discs and an updated non-genuine copy, which came with the car when I bought it.
However, neither now work.
Just wondered:
Should one or both of then work - even if it means missing new roads etc that would appear on updated versions?
or
Do they cease to work when newer versions are released?
If I should be able to at least get an 'old' map to display, what could be the problem?
Any help would be most appreciated.
Thank you,
David
Hi David
No they don't stop working when a new one comes out.
I can understand a copy failing as I had one do that to me.
Can I suggest that you 1st put the OEM one in and then go to info and scroll down to "About" or Map version.
If the writing does not show anything then there may be a loose connection.
But b4 you go ripping stuff out put a cleaning disc direct into the map CD housing behind the drivers seat,
I really need to see it myself as I am sure its something quite simple.
If your like me you want it to work.
Not go and buy something completely different.
When mine system threw a wobbly with the bluetooth. I missed it like heck. Girnet came and sorted it .
Anyway try that out 1st.
Do you live anywhere near Morden?
If so I could maybe take a look.
Edited by 4RE Leather
Hello and thank you all for such prompt responses.
The CD is whirring away happily and I get past the 'I agree' opening screen with ease. Can get all the menu options to show, but screen display is just black with a random red arrow...
Maybe a CD cleaner would be a good starting point?
Have to say, it's a pretty useless system anyway from my limited experience when it did work: takes ages to programme an address in thanks to a very laborious input system and you can't just postcode search, which seems VERY poor.
If it's not a clean that's needed, ant further suggestions?
Thank you,
David
