Sandpaper
xStric9x
This may sound like a strange question but what is the finest sand paper you can buy?
The inside of my alloy has a small bit of residue which has glued itself to my wheel. I've tryed everything to get it off and it won't budge so last resort is to use some really fine sandpaper but i don't know which is the finest grain.
Help please :thumbs:
Sorry to hog this space mate, I have some wierd residue appear on my alloy wheels not sure if its traps water stain or if the laquer is coming of but only in certain places, would clay bar sort this? I accidently used polish instead of wax but it was this:
http://www.cleanyourcar.co.uk/shop/engi ... p_106.html
Wheels are only 5 weeks old :wacko:
As for sandpaper I would not use, normally white spirit worked wonders but not sure if will damage your wheels I would test on a small area and if ok, then goes for it :dry:
The NXT is only for polishing bare metal such as aluminium etc, it can remove laquer coat so be very carefull not to use on the wheels, the coatings paticularly on Jap wheels is very thin and doesn't take much to remove.
There is also a wheel cleaner I bought years ago, I think its called MC2 also known as viro-sol, its made from non acidic degreasing liquids etc. I think its used on boat decks and hulls.
Available here:
http://www.mustang-cleaningsupplies.co. ... EASER+5LTR
and here:
http://www.olympiccleaning.com/
Its also about the best wheel cleaner bar none that I have used. Dilute 1:10 with water, spray fine mist onto wheels covered in brake dust, leave five minutes and rinse off. use it neat on hard spots and its perfect, also works under engine bays too.
if you were going to try something as drastic as fine sandpaper what about a really fine grade steel wool? I have some really fine stuff that I've used on exhaust pipes without it stratching but you can get even finer than that. At the end of the day if it goes wrong you can still get the wheel refurbished for about £50.
