OEM intake Pipe.
Mike k-g
Right!! sprayed my OEM intake pipe last week...quiet please with it..Upon installing it the paint crack and chiped all over the place now looks pants. :rant: sooo anyone tell me how to remove old paint from pipe to start again?or does anyone have a old pipe knocking around to let go cheap? DE engine by the way...trottle body to MAF sensor i need only. yes i did use plastic primer before you ask.lol.
Mike K-g
Mike if you have some wet & dry sand paper (fine grade like 800grit or 1000) just use plenty of soapy water and rub all the bits where it has chipped/flaked until they are smooth, ...so you can't feel where they join with the paint if that makes sense.
Then just key up the whole thing with a scotch pad & repaint.
Should sort it out without the need for another pipe. :thumbs:
