Front strut brace to fit with 1\2 inch spacer
Ryajarv
can you not use spacers under the o/e strut mounting points?
For a 5/16 yes, but if you space higher then you're hitting the hood.
1/2" is pretty useless in design, either no strut or get a APS.
Bit of a boo boo by Motordyne to be honest.
I'm 100% sure that when I had my 5/16" spacer fitted that there was about 10mm or so clearance, so if you have a 10mm spacer/washer fitted to each nut/bolt of the strut you should be fine.
Edited by KyleR
