lbeddowscbr Posted November 1, 2014 Share Posted November 1, 2014 Sorry if this has been covered before. got a 54 plate with brembos and when i press the brakes i have to let off and press again as the brakes don't feel they have binded properly first bite. is this a common thing and is it worth buying some braided lines or do you think it could be something else? Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 1, 2014 Share Posted November 1, 2014 When was the fluid last replaced? Could be old fluid, or air in the system. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 1, 2014 Share Posted November 1, 2014 As what Dan has said, Fluid has probably boiled or degenerated. New upgraded fluid and a good bleed to get ALL the air out. will fix your issues. Alex. Quote Link to comment Share on other sites More sharing options...
lbeddowscbr Posted November 1, 2014 Author Share Posted November 1, 2014 Not sure to be honest. Had it since February and I've not done it. Is it worth buying braided lines as well while in changing the fluid? Quote Link to comment Share on other sites More sharing options...
lbeddowscbr Posted November 1, 2014 Author Share Posted November 1, 2014 And while were on the subject, what brake fluid do people recommend Quote Link to comment Share on other sites More sharing options...
KyleR Posted November 1, 2014 Share Posted November 1, 2014 Buy a litre of Motul 600 off eBay for about £16 and bleed the whole system. It is pretty common that you have to double tap the brakes to get the best from them, but it's how much of a difference that matters. If it's like night and day then get the fluid and sort it, but be sure to bleed them in the correct order which I think is NSR, OSF, OSR, NSF and always the inner bleed nipple first as there is 2 on each caliper. Quote Link to comment Share on other sites More sharing options...
lbeddowscbr Posted November 1, 2014 Author Share Posted November 1, 2014 Great stuff. Thanks for the advice guys Quote Link to comment Share on other sites More sharing options...
