alexdax Posted November 20, 2014 Author Share Posted November 20, 2014 Quote Link to comment Share on other sites More sharing options...
alexdax Posted November 20, 2014 Author Share Posted November 20, 2014 all done Quote Link to comment Share on other sites More sharing options...
alexdax Posted November 20, 2014 Author Share Posted November 20, 2014 in his proper place Quote Link to comment Share on other sites More sharing options...
alexdax Posted November 20, 2014 Author Share Posted November 20, 2014 this is tough after many many bolts and nuts... :yawn: 1 Quote Link to comment Share on other sites More sharing options...
alexdax Posted November 20, 2014 Author Share Posted November 20, 2014 time for a little help from the forum... i have a little problem... My Z doesent have spark on the spark plugs... i´m going to folow the loom from scratch because i think it can only be one plug loose. like the crank one or the cams ... or even a ground terminal... any advice on this? Quote Link to comment Share on other sites More sharing options...
martybhoy Posted November 20, 2014 Share Posted November 20, 2014 (edited) The rebuilt motor looks mighty impressive! Edited November 20, 2014 by martybhoy Quote Link to comment Share on other sites More sharing options...
ZEUS Posted November 20, 2014 Share Posted November 20, 2014 Nice work and loving all the pictures Quote Link to comment Share on other sites More sharing options...
evilscorp Posted November 20, 2014 Share Posted November 20, 2014 Do the cosworth head gaskets get the cooling block mod? Like HR gaskets? Nice work =) Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 20, 2014 Share Posted November 20, 2014 Fantastic work Alex. Have you managed to trace the fault to find out why the plugs aren't sparking? Hopefully it is just something simple like a plug not connected. Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 20, 2014 Share Posted November 20, 2014 As you have painted the front Cam chain cover check this earth - I put one back together with paint on and had no spark took ages to sort May help Quote Link to comment Share on other sites More sharing options...
alexdax Posted November 21, 2014 Author Share Posted November 21, 2014 As you have painted the front Cam chain cover check this earth - I put one back together with paint on and had no spark took ages to sort May help i clean all the paint out and conected the earth on the right boult, but nothing... i´m going to see if the crank sensor is ok... Quote Link to comment Share on other sites More sharing options...
alexdax Posted December 9, 2014 Author Share Posted December 9, 2014 ok its all done its working great will do some 1K miles in low boost just in case :teeth: Quote Link to comment Share on other sites More sharing options...
alexdax Posted December 9, 2014 Author Share Posted December 9, 2014 (edited) the santa claus is coming early this year for me PSS10 - 2014 model Edited December 9, 2014 by alexdax Quote Link to comment Share on other sites More sharing options...
Vlad Posted December 9, 2014 Share Posted December 9, 2014 Awesome work mate! Well done! What was the issue with spark then? Quote Link to comment Share on other sites More sharing options...
alexdax Posted December 9, 2014 Author Share Posted December 9, 2014 because i dont get any fault code my guess is on the crank timing, I disassenbled the chains and i think i was one tooth from the right timing. now is all nice and working another thing that i realised is that the cams sensors plugs arent the best ones because they make the "click" but they are not connected, you have to make shure even after you hear the "click" but i guess that wasnt the problem because i was not gueting any fault code. Quote Link to comment Share on other sites More sharing options...
Keyser Posted December 9, 2014 Share Posted December 9, 2014 Nice one - well done on getting her running again Nice suspension as well Quote Link to comment Share on other sites More sharing options...
