Kaveney Posted October 28, 2014 Posted October 28, 2014 I have said the Mrs can drive my 350Z for the week but she has just phoned up saying it has run out of fuel ( I did say fill up as I don't think the needle is reading correct ) . I have one the fuel sender clean but since doing that the needle will only go down to quarter of a tank and no lower . Have I over cleaned the strip or have I trapped the float on something . The guage does go down as it was on half way and went down to quarter of a tank . Alan Quote
Wayne370Z Posted October 28, 2014 Posted October 28, 2014 I think the problem here is ; - letting the missus drive the Zed ..... 2 Quote
Kaveney Posted October 28, 2014 Author Posted October 28, 2014 Yes this may have been the problem as she has just put 95ron in it as well Quote
WINKJ Posted October 28, 2014 Posted October 28, 2014 Yes this may have been the problem as she has just put 95ron in it as well good God man... what were you thinking!!! :scare: :scare: 1 Quote
Kaveney Posted October 28, 2014 Author Posted October 28, 2014 LOL anyway does any one have any thoughts on this . I will takeout the sender at the weekend and have a look . Alan Quote
14N Posted October 28, 2014 Posted October 28, 2014 I hope you still get to keep the Zed after your divorce is complete. Quote
chirag1988 Posted October 28, 2014 Posted October 28, 2014 Chuck some fuel additive into it while the 95 ron is in - then just top up with V Power Quote
Kaveney Posted October 28, 2014 Author Posted October 28, 2014 What would be best to fix the sender ? Before the clean it would go to the red so I have done something but not sure what . Alan Quote
Alize Posted October 28, 2014 Posted October 28, 2014 But did you tell her only 97 or V Power????😱 Sent from my iPhone using Tapatalk Quote
WINKJ Posted October 28, 2014 Posted October 28, 2014 Alan, someone will come along shortly and provide you with some useful information. none of us that have posted are in such a position!!! so hold out a couple more hours and I am sure it will be sorted... no doubt ZMANALEX can help 1 Quote
GIXXERUK Posted October 28, 2014 Posted October 28, 2014 Alan, someone will come along shortly and provide you with some useful information. none of us that have posted are in such a position!!! so hold out a couple more hours and I am sure it will be sorted... no doubt ZMANALEX can help +1 or google search as this has come up before Quote
ZMANALEX Posted October 28, 2014 Posted October 28, 2014 Providing that the gauge is not faulty and the senders are not fooked then if may be that one of the floats is stuck or you have bent the float wire. What happens to the gauge when you disconnect the looms to the senders? Have you refitted the senders properly to the fuel pump housings ? What I would do is remove both the sender units and give them another clean. When you have them out make sure that you have not bent the float wire on the driver's side. Fully test them before refitting to the tank, simply by moving the float, checking the gauge with the ignition on and the looms hooked up to the senders. Another common issue is that the float on the driver's side can become entangled with the the fuel syphon pipe if you are not careful. Quote
Kaveney Posted October 28, 2014 Author Posted October 28, 2014 Many thanks I will have a look at the week end . Will I be the drivers side that should be at fault then as this was the harder one to do . Thanks Alan Quote
Kaveney Posted November 3, 2014 Author Posted November 3, 2014 Ok just for a note I think I have fixed this problem ( thanks ZMANALEX ) . It would seem that when I cleaned he senders I trapped the float with the syphon pipe and this was the cause of the needle not going below quarter of a tank ( this was on the drivers side ) . Removed the sender / pump ad then refitted it moving the syphon pipe out f the way . Turned car on and needle was on the red filled up with £ 40.00 an now the needle is on quarter of a tank . Will check that the needle goes down but think this has sorted the problem . Alan Quote
WhackyWill Posted November 3, 2014 Posted November 3, 2014 Have a read through this... http://www.madmaxx.myzen.co.uk/350z/fuelgaugefix/Fixing%20the%20FuelGauge.pdf Quote
Kaveney Posted November 3, 2014 Author Posted November 3, 2014 Yes mate I have done all that but must have trapped the sender but all fixed now Quote
