New fan for 350z 2007 313
chrisday1990
hey guys I have posted a link, it looks cheaper to replace the entire fan deck rather than the motors does this look in line with what I need.
http://www.quirkparts.com/nissan/350z/21487cd00a/2007-year/grand-touring-trim/3-5l-v6-gas-engine/belts-and-cooling-cat/cooling-fan-clutch-and-motor-scat/?part_name=engine-cooling-fan-motor
This is the normal replacement,
http://www.mishimoto.co.uk/mishimoto-nissan-350z-aluminum-fan-shroud-03.html
its not a straight swap as the the wiring is different but its a simple conversion (there is a guide on the forum). The one above looks far too expensive for just a motor
Zmanalex sells replacement motors for ~£50
From a previous thread about the same thing basically....
As others have said the likely cause is the fans not working. When the car is running and comes up to working temperature you should see one of the fans start to work, if not then it's probably had it. The other fan works when the A/c is turned on so you can check that by turning that on when the cars running.
Some members have taken their fan motors apart and cleaned them/replaced parts but usually this is just a temporary fix. Link: http://www.350z-uk.c...rs-youtube-vid/
Link: http://www.350z-uk.c...-small-how-too/
Alternatively you could get a good used set of OEM fans from zmanalex on here or from one of the other members/traders that are currently breaking 350Z's.
Another alternative is to take the opportunity to upgrade at a cost more reasonable than the OEM parts from Nissan. As Jumping350 mentioned you can get the Mishimoto fan shroud which Clark Motorsport, Tarmac Sportz and others sell on here.
Link to Tarmac's fans although PM him for best delivered price; http://www.tarmacspo...S-350Z-03_.aspx
Good luck. :thumbs:
Link here if you want to read more; http://www.350z-uk.c...iven-250-miles/
Hope that helps. :thumbs:
