Coolant question
telboy83
Guys wandering if anyone can help?the other day my fan packed up causing coolant to overheat and leak.ihave a new fan coming but will have to put more coolant in now.ive never really done it before,is it a case of just poring it thro radiator or coolant tank or is there a procedure,I don't want get any air locks or anything
I usually leave the rad cap off and run the engine until the thermostat opens, at this point the level will usually drop so you can top up, if it starts to overflow put the rad cap beck on and then you can check the levels again when cold.
This is for coolant loss like yours not general topping up.
