jayrishi Posted October 26, 2014 Share Posted October 26, 2014 Hello all i've installed a kenwood 5240bt everything works apart from the sound. Im getting no sound whatsoever. Any help on this?? Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted October 26, 2014 Share Posted October 26, 2014 Turned the volume up? I'm sorry but I had to say it Quote Link to comment Share on other sites More sharing options...
6705russell Posted October 26, 2014 Share Posted October 26, 2014 If it's anything like the Pioneers there is a separate cable to turn the factory fitted amp on, on the Pioneer I fitted I think it was blue/white? Quote Link to comment Share on other sites More sharing options...
Beavis Posted October 26, 2014 Share Posted October 26, 2014 If it's anything like the Pioneers there is a separate cable to turn the factory fitted amp on, on the Pioneer I fitted I think it was blue/white? +1 Quote Link to comment Share on other sites More sharing options...
jayrishi Posted October 26, 2014 Author Share Posted October 26, 2014 yes volume is up haha its already been fitted with aftermarket single din and amp. so not sure whats wrong with it. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2014 Share Posted October 26, 2014 Has the amp turn on wire (remote) been connected? 1 Quote Link to comment Share on other sites More sharing options...
jayrishi Posted October 26, 2014 Author Share Posted October 26, 2014 yeh thats been connected to Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 27, 2014 Share Posted October 27, 2014 Is the amp actually turning on? is the fuse OK? Quote Link to comment Share on other sites More sharing options...
jayrishi Posted October 27, 2014 Author Share Posted October 27, 2014 Yeh it's on and fuse is fine On the back I got a blue wire coming out is that meant to be connected to something? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 27, 2014 Share Posted October 27, 2014 Yeh it's on and fuse is fine On the back I got a blue wire coming out is that meant to be connected to something? On the back of what? the amp or head unit, the amp remote/turn on wire is usually blue or blue and white, I presume you have it connected via phono and not line level? have you checked these and selected the appropriate setup from the HU menu? 1 Quote Link to comment Share on other sites More sharing options...
jayrishi Posted October 27, 2014 Author Share Posted October 27, 2014 Blue wire from the hu..I will post a pic that may help you see what I mean Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 27, 2014 Share Posted October 27, 2014 Here is the install manual if you haven't got it, there is not a blue only wire, only a blue and white wire which is the turn on signal wire for and external amp, if this is not connected the amp wont turn on (unless you have wired the amp to be permanently on, which is not a good idea) http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/MultiMedia/DDX5024%20DNX5240_BT%20installation.pdf Quote Link to comment Share on other sites More sharing options...
