Booking a p3
mikejbry
Hey chaps, I am booking my HR into FCM Motorsport in Bristol, I have a quote for a p3 for the following;
engine oil (10/60 fully synth or 10/40 semi synth your choice) filter change
gear box oil
rear diff oil
brake and clutch fluid
spark plugs replaced
check all lights aux belts suspension and so on. all oils will be castrol and the brake fluid will be rbf600 race fluid.
Seems good to me, I am assuming they will change the air filters etc as well. What do you lot think with regards to the oil options?
Cheers
Mike
£350 plus vat
Seemed reasonable looking through what the owner before me spent on servicing with Nissan!
I am more of a home mechanic when it comes to my bikes and cars usually, but as this one has every stamp from new and only on 33k miles, I feel it should get another.
Nissan specifies 5w30 engine oil, and I think Castrol Edge would be the only contender on quality in the Castrol range. Personally I would prefer to see Fuchs Race Pro S, or some use Motul.
Perhaps you should ask why they are recommending 10/60 or 10/40, seems odd.
