Is there a fix for this rattle please?
Zeezeebaba
What about wedging a soft piece of piping/padding between the trim & the windscreen?
Either something like this: http://www.carbuildersolutions.com/uk/9mm-x-6mm-self-adhesive-neoprene-rubber-p-section
Or this: http://www.carbuildersolutions.com/uk/25-x-6mm-self-adhesive-foam-rubber-strip
Very cheap to buy a metre of either so that's what I'd try. :thumbs:
Ironically the left hand n/s section is quiet, just the side with the led rattles.Also I still have two weeks of bannana arm ball joint knock to tolerate until it goes in to be fixed which rates higher on the annoying list :) hopefully the wheel won't fall off before then.
