_BR1TT0N_ Posted October 9, 2014 Share Posted October 9, 2014 Hey guys, just wondering there is a knocking noise from the front drivers side corner on my friends 350z. Sounds like something is rattling/bumping around when driving. Any ideas? Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted October 9, 2014 Share Posted October 9, 2014 might be something to do with the banana arm bush? 1 Quote Link to comment Share on other sites More sharing options...
zebedy Posted October 9, 2014 Share Posted October 9, 2014 check the bushes and if your replacing them, get the polyurathane type like polybushes etc. Much better than rubber. Also get your front wheel up in the air with a jack and push the top of the wheel in and out of the arch to see if there is play. Might be the wheel bearing?? but sounds like a knock from a worn banana arm bush like rock steady said Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted October 9, 2014 Share Posted October 9, 2014 also worth a check while you're under there... the coil spring - check it hasnt snapped and a coil is rattling inside the spring 1 Quote Link to comment Share on other sites More sharing options...
_BR1TT0N_ Posted October 9, 2014 Author Share Posted October 9, 2014 Okay, thanks guys! Will jack it up and take a look under there! If it is the bushes. Still learning at the moment, are they easy to change? Quote Link to comment Share on other sites More sharing options...
