Andy Posted September 15, 2007 Share Posted September 15, 2007 Need some help! For some strange reason, my passenger window has stopped working! I have had both door cards off and checked all the connections and they look fine. I haven't checked the fuse as i'm not sure where it is but i'm not too concerned about the fuse as I would assume that the window motor alone wouldn't have a seperate fuse...I would assume it would be for either both windows or for the whole left door and my drivers door and both mirrors still work electrically. I am a tad reluctant to take the metal plate off the door as it is a nightmare re-aligning the window runners with the bolt holes so my question is.....does anyone have an idea of what it could be??? The assumption I am working on is that is could be the motor itself has failed and I can check this by checking the cabling going into it to see if it is showing a charge but I would have to take the metal plate off and I would rather not for the time being if I don't have to!!! I have done a search but there doesn't seem to be anything of use on fuses or window problems but I did find something called a "Windows Reset Procedure" (If anyone says push Ctrl, Alt + Delete I won't find it funny!!! ) Does anyone know what this procedure is so I can try it??? Any ideas??? Thanks in advance guys Quote Link to comment Share on other sites More sharing options...
lomoto Posted September 15, 2007 Share Posted September 15, 2007 try here for window reset info http://www.350z-uk.com/forum/viewtopic ... ndow+reset Quote Link to comment Share on other sites More sharing options...
Andy Posted September 17, 2007 Author Share Posted September 17, 2007 Excellant, thanks for the help mate! On a sidenote, does anyone know where the internal fuse box is located? I know of the one by the battery but I am assuming there is an internal one as well!! Nissan have quoted me £365 for a new motor!! Quote Link to comment Share on other sites More sharing options...
rickya Posted September 17, 2007 Share Posted September 17, 2007 Driver footwell on right hand side, far back, stupid, backbreaking place to put it. Good if your a contortionist in Circus Quote Link to comment Share on other sites More sharing options...
H5 Posted September 17, 2007 Share Posted September 17, 2007 It could be the switch itself. Have you got a circuit tester / multimeter? Find out which wire takes the power from the switch to the window and check to see if it's sending any signal. Quote Link to comment Share on other sites More sharing options...
Andy Posted September 17, 2007 Author Share Posted September 17, 2007 Found the fusebox, cheers for that!! All fuses etc are fine! Just about to rip the door apart and see what's what again!!! Quote Link to comment Share on other sites More sharing options...
Andy Posted September 17, 2007 Author Share Posted September 17, 2007 I don't suppose anyone has a relevant wiring diagram at all do they???? Quote Link to comment Share on other sites More sharing options...
Beavis Posted September 17, 2007 Share Posted September 17, 2007 I don't suppose anyone has a relevant wiring diagram at all do they???? You could download the relevant service manual for your car (year) plenty of diagrams in them. http://www.350z-tech.com/zwiki/Service:Index Quote Link to comment Share on other sites More sharing options...
Andy Posted September 18, 2007 Author Share Posted September 18, 2007 Massive thanks for the wiring diagrams!! They were a great help as is the rest of the maunal!!! By way of an update, the switch is throwing out some weird voltage readings so think it could be that but still not 100%. Just for the information logs, if the electrics do go and you need to raise the window, it is possible to do it manually whilst still locking it in situ. The whole door has to be stripped down ie: door card off, metal plate off, all bronze locator screws taken off. The motor and housing has to be removed from the silver facia and then using a 1/4" drive in the middle of the motor housing, the window can be raised maually. Just remember to leave a slight gap at the top as the window won't self-drop or self-raise if the electrics have gone!!! It's a bit of an effort and needed 3 of us to do it as one has to hold the window, one the motor and housing and the other wound the window up but as a short term solution it is do-able. Quote Link to comment Share on other sites More sharing options...
LeeRG Posted February 6, 2008 Share Posted February 6, 2008 You have probably checked, but haven't mentioned it...... have you accidentally pressed the window lock button on the drivers side? Quote Link to comment Share on other sites More sharing options...
Andy Posted February 6, 2008 Author Share Posted February 6, 2008 Yeah checked that Still haven't got to the bottom of the problem though but to be fair I haven't looked at it for a good few weeks! to the site by the way Quote Link to comment Share on other sites More sharing options...
teddyonholiday Posted March 11, 2008 Share Posted March 11, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door. The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 11, 2008 Share Posted March 11, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger Quote Link to comment Share on other sites More sharing options...
jim Posted March 12, 2008 Share Posted March 12, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Quote Link to comment Share on other sites More sharing options...
Beavis Posted March 12, 2008 Share Posted March 12, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Hiding from you Jim because he owe's you an explanation. http://www.350z-uk.com/forum/viewtopic ... 5&start=45 Quote Link to comment Share on other sites More sharing options...
jim Posted March 12, 2008 Share Posted March 12, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Hiding from you Jim because he owe's you an explanation. http://www.350z-uk.com/forum/viewtopic ... 5&start=45 Mind you, we'll not be laughing if he comes back with a GTR. Quote Link to comment Share on other sites More sharing options...
teddyonholiday Posted March 12, 2008 Share Posted March 12, 2008 Sorry to all you guys who have missed me but I have been a bit busy in the new job but I have managed to start finding time to get back on here so if I am needed or if you have a techy probelm you cant solve just PM me and i will try and help. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 12, 2008 Share Posted March 12, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Buying a car Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2008 Share Posted March 13, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Buying a car How you getting it home? Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 13, 2008 Share Posted March 13, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Buying a car How you getting it home? Gonna drive it through China,Mongolia, Russia, Germany, Holland and France Quote Link to comment Share on other sites More sharing options...
jim Posted March 13, 2008 Share Posted March 13, 2008 The strange voltage is a waveform from the encoder, the control of the passenger window is carried out in the drivers window module there is most likely a broken wire to the door post or to the drivers door.The diagrams have been published before but if you havent found them by the weekend i can publish them when I get home. Bloody hell, hello stranger What you up to in Tokyo, Sarnie? Buying a car How you getting it home? Gonna drive it through China,Mongolia, Russia, Germany, Holland and France Now that's what I call running it in. Quote Link to comment Share on other sites More sharing options...
