bigjackb Posted October 4, 2014 Share Posted October 4, 2014 Ive been having a problem over the last few weeks of getting water into the bottom of the boot whwre the spare wheel is. However this only happens when It has been raining heavy and I've driven the car. When I was the car there's never any water leaks in which makes me think it must be a seal under the car and water coming up the way. Has anyone had this problem before? And has anyone got any ideas how to try and solve. Thanks! Quote Link to comment Share on other sites More sharing options...
bigjackb Posted October 4, 2014 Author Share Posted October 4, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted October 4, 2014 Share Posted October 4, 2014 Is it parked on the flat or a slope when not in use? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted October 4, 2014 Share Posted October 4, 2014 Is it parked on the flat or a slope when not in use? This only happens when the car is driven in rain the op said Quote Link to comment Share on other sites More sharing options...
Ricey Posted October 4, 2014 Share Posted October 4, 2014 Get in the boot (if you can!) and get a mate to fire a jetwash every which way but loose. Hopefully you'll see where it's coming from. Quote Link to comment Share on other sites More sharing options...
JEMAN Posted October 4, 2014 Share Posted October 4, 2014 Yep.....sounds like as it's when your driving it's more than likely coming from underneath........but I would still check all seals around the boot as when driving the wind can whip the rain in......good luck Quote Link to comment Share on other sites More sharing options...
bigjackb Posted October 4, 2014 Author Share Posted October 4, 2014 Can anyone tell me if there are any seals underneath the boot floor that could possibly perish? Quote Link to comment Share on other sites More sharing options...
Neilp Posted October 4, 2014 Share Posted October 4, 2014 Have you had the rear lights out at all? Take them off and check the rubber seals are on every screw hole. This will be where it's coming from 1 Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted October 5, 2014 Share Posted October 5, 2014 Is it parked on the flat or a slope when not in use? This only happens when the car is driven in rain the op said Ahh yes lol, silly me. Quote Link to comment Share on other sites More sharing options...
bigjackb Posted October 5, 2014 Author Share Posted October 5, 2014 Will check the lights this morning and let you know if I get any further forward! Quote Link to comment Share on other sites More sharing options...
bigjackb Posted October 5, 2014 Author Share Posted October 5, 2014 So i have discovered that it's the vent in the boot that the seal has failed on. Does anyone know where I would be able to buy one? Quote Link to comment Share on other sites More sharing options...
david85williams Posted November 25, 2014 Share Posted November 25, 2014 Ive go the same problem. Can you tell me what vent you are talking about? Quote Link to comment Share on other sites More sharing options...
AndyG8nby Posted November 25, 2014 Share Posted November 25, 2014 I had the same problem, there is a vent in each side at the rear of the boot. The original seal seems to be made of foam so i just used a mastic sealent and fixed them back in. Quote Link to comment Share on other sites More sharing options...
bigjackb Posted November 25, 2014 Author Share Posted November 25, 2014 Once you take the foam stuff out the boot floor you will see a vent in each corner. They are really easy to just push out then you will be able to see what seal has failed. Pm zedmanalex that's where I got another seal from. Quote Link to comment Share on other sites More sharing options...
david85williams Posted November 25, 2014 Share Posted November 25, 2014 Cheers guys. Do the black foam bits in the boot come out easily? Quote Link to comment Share on other sites More sharing options...
bigjackb Posted November 25, 2014 Author Share Posted November 25, 2014 Well mine didn't anyway and few cuts and a lot of swearing later they were out! Quote Link to comment Share on other sites More sharing options...
