Marzman's Mercedes G-Wagen build UPDATE Wheels fitted pg 6
marzman
Bollocks.
Just came to start the car tonight and it's dead as a dodo.
I've not started it in 2 weeks, since i pressure washed the engine.
Stupidly, i didnt have the engine running whilst cleaning it (although i did spend 4 hours cleaning).
On turn of key i can hear the fuel pump prime, but then on turning all the way i just get one loud click and nothing else.
I've checked the fuses, checked all cables are secure, inspected the dizzy cap, earths seem okay, given the started motor a few whacks with the hammer... all without any change in symptoms.
Worryingly i found out tonight the starter motor appears to be right on the bottom of the engine, by the bottom of the bell housing on the gearbox... and this is where i concentrated a lot of the water whilst pressure washing. Am i likely to have killed the started motor?? Are they recoverable??
On a positive note, i got my milled spacers back, and got the 2nd wheel on tonight, and it looks badass!
Does it have a distributor on it?
Sounds strange but have you tried liberally spraying the engine electrics/distributor with WD40?
Old trick that works on older model cars when the distributor has got wet. Worth a shot? :shrug:;)
Edited before glrnet has a heart attack due to use of north american british english word. :lol:
Edited by GMballistic
Just popped into Mercedes and picked up the repair panel i ordered last week (£100.03). Looks pretty cool.
Also ordered a fire extinguisher which arrived today.
Lastly i bought a multimeter from Toolstation to help diagnose my non-starting issues.
Oh, and whilst in the Mercedes dealers, i noticed they had a current model G in...!!
Oh also, i bought a battery charger from Aldi this morning - £13 and it's a really good bit of kit! Got the battery on charge now. It was reading 11.75 volts while on the car, although i've not got a drop tester to check the Amps. Will give it a charge and try it again.
Well I finally got my wheels fitted, after having the inner face milled out to fit the larger hub on the car.
Im pleased with how they look. :)
On the downside, the car still wont start, and the battery is fully charged. I can hear the solenoid clicking, but the motor doesn't engage. I need to do some googling to figure out the next steps...
Edited by marzman
  On 24/11/2014 at 00:08, leonk said:
I don't feel so bad about my slow progress now! Only kidding, I know you've had a nasty case of Ebola this week. All recovered now?
No, i cant shift it. :dry: Brought on by too much booze in Manchester last weekend I think.
