bought HFC.. now Y pipe 'flexi' has broken
Spatt
As title.. i bought some HFC running to a Nismo back box (not that i think that matters) and one of my flexible connections has started leaking!
Its sounds awful and needs replacing. so, options.
can i have my original Y pipe modified and have solid pipes parts put in?
do i replace with a standard Y pipe part? .......................I have heard this will simply start leaking again due to high pressure in the Y pipe?
Or do i need to upgrade to a solid stainless Y pipe if so what are the advantages of this?
thanks in advance,
Matt
I wouldn't be spending near £300 on a Y pipe just because a flexi has started blowing. It shouldn't cost more than £90 for have a new flexi fitted, or indeed you could have both of them cut out and a solid pipe welded in their place for about the same money, but solving both sides. Some may say that the weld won't be as smooth and therefore lose a HP or 2 or some rubbish, but even a messy weld will be smoother than the flexible steel that was there before hand.
