Mike k-g Posted September 29, 2014 Share Posted September 29, 2014 Anyone tell me if there's ah guide on changing coolant? Had a search drew ah blank. Cheers Mike Quote Link to comment Share on other sites More sharing options...
jimmy1280 Posted September 29, 2014 Share Posted September 29, 2014 There may be a guide somewhere Mike, I've just changed mine if you drain from the plug on the radiator you will drop about 5L, I'd heard that if you do the block also it's possible to get air locks so I did mine by dilution replaced 5L close system back up let it run round for a while then repeated the process. Hope this helps Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 29, 2014 Share Posted September 29, 2014 This should help a bit Mike I hope. Link: http://www.350z-uk.com/topic/74594-coolant-change-bleeding-system/ Couldn't find a guide sorry. 2 Quote Link to comment Share on other sites More sharing options...
Watshot Posted September 29, 2014 Share Posted September 29, 2014 Scroll down to page 10. http://www.nicoclub.com/FSM/350Z/coupe/2006/co.pdf I could only get to one of the block drain bolts but managed to swap out about 8.5 litres, so was happy with that. 1 Quote Link to comment Share on other sites More sharing options...
