ThreadLock Posted September 22, 2014 Share Posted September 22, 2014 So when I bought the car, I noticed that the rear brake pads were rattling like mad. I assumed that they just needed replacing as they must be worn out. Once the wheels were off it was apparent that they were not worn and were in fact like new (I'd say about 3mm wear in total). I decided to swap them out anyway for the new Mintex MDB2261 which were the exact same as what came out. After a few days they started to rattle once again as the Copper Grease and pads bedded down. Now... Since then I have found out that my car is an import and as a result, its a Fairlady? I have also been advised that I now need the following Nissan part 440808H325 which is an Anti Squeal/Anti Rattle kit. Is this right guys? Is this what I need or do I have the wrong pads? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted September 22, 2014 Share Posted September 22, 2014 If the shims above in your picture are not there you will need them as that's what will cause your rattle. The brakes will work fine but I can imagine the noise will be very annoying Quote Link to comment Share on other sites More sharing options...
ThreadLock Posted September 22, 2014 Author Share Posted September 22, 2014 The noise is horrid! Im ashamed to drive it around at the mo..! Quote Link to comment Share on other sites More sharing options...
Ebized Posted September 22, 2014 Share Posted September 22, 2014 Yep, set of shims should bring back peace and quiet from your rear end Quote Link to comment Share on other sites More sharing options...
ThreadLock Posted September 23, 2014 Author Share Posted September 23, 2014 Rattle kit fitted and took the car for a spin... Whoop Whoop! Loving the peace and quiet! Now for the squeaks and rattles in side the car... First one will be the one from the dash panel behind the clocks. There is always something! Quote Link to comment Share on other sites More sharing options...
ThreadLock Posted September 23, 2014 Author Share Posted September 23, 2014 For the record guys the Anti Rattle Kit was only 16 Euros... 1 Quote Link to comment Share on other sites More sharing options...
