photos after lowering
mrt
tein are 25mm drop where as eibach are 30mm iirc, i would go for the tein personally, a good compromise on speed humps, comfort and looks :thumbs:
and.......they are a quality spring, people say springs are springs but they are not, my brother and i both had 911's he had eibach fitted and I had h&r springs, the h&r offered much more comfort but with the same handling
Wrong front tyres mate, 245/35/19 are correct. Stick whatever you want on, but 245/35's are correct.
Mrt has been informed of tyre size combo's Kyle. ;)
See thread here; http://www.350z-uk.com/topic/90588-changing-from-stretched-on-105-and-95-js/
You are right it should be 245/35's on the front (as I have) but he's wanting to save some cash by reusing his old rear tyres which have good tread left and are 255/35's ~ thus saving him some cash by sticking them on the front. :thumbs:
Thanks for the positive feedback guys.Really encourages me to move forward with the planned mods.
Davie wagon. They were re aligned after Falcon fitted them.
Gonna need them checked again tomorrow when I replace the tyres.
Kyler ...245,s are what others use with 275's rear. The tyre manufacturers consider 245 as the lower acceptable size on 9.5 j,s 265 being the optimum. Gonna try my rear 255,s on the front and new 275's on the rear to see whether there is any rubbing / handling problems. If so I will just slot new 245's on. My rear 255's are near new.
Gixxer currently Bridgestone Potenzas r050. Quite stretched.
Keyser ..... Followed your build thread and saw it on eBay...tempted to buy that one as we'll ... Amazing job and a good buy for a lucky new owner.
Thanks again everyone.
Exhaust is an in Invidia Gemini dual with Titanium tips
Current tyre sizes are 235/35 et 21 front and 255/35 et 24 rear. Stretched but changing tomorrow.
http://www.filmon.com/tv/api/channel/13?session_key=447522f7ba37f8f1b157731960a22f37&quality=high
You should easily be able to run 285 rears with that off set , should look lower tommorrow when the stretched tyres are gone .
This tyre fitment guide might help and is part of the reason im going to try the 255 fronts
Rim width-----Min tyre width-----Ideal tyre width-----Max tyre width
7.0 inches-----195 mm--------205 or 215 mm-----------225 mm
7.5 inches-----205 mm--------215 or 225 mm-----------235 mm
8.0 inches-----215 mm--------225 or 235 mm-----------245 mm
8.5 inches-----225 mm--------235 or 245 mm-----------255 mm
9,0 inches-----235 mm--------245 or 255 mm-----------265 mm
9.5 inches-----245 mm--------255 or 265 mm-----------275 mm
10.0 inches----255 mm--------265 or 275 mm-----------285 mm
10.5 inches----265 mm--------275 or 285 mm-----------295 mm
11.0 inches----275 mm--------285 or 295 mm-----------305 mm
11.5 inches----285 mm--------295 or 305 mm-----------315 mm
12.0 inches----295 mm--------305 or 315 mm-----------325 mm
12.5 inches---305 mm---------315 or 325 mm-----------335 mm
Thanks GM.They are in need of polishing when I change them for winter.
Tying to find the best rim wax cause they,re Anodised an can stain easy/
A few rim wax related threads for you to read;
http://www.350z-uk.com/topic/41637-rim-wax/
http://www.350z-uk.com/topic/84178-rim-wax-applicators/
http://www.350z-uk.com/topic/31241-need-your-rim-waxed/
http://www.350z-uk.com/topic/22861-advice-on-polished-lipsdishswheels-please/
:thumbs:
