liamgdr Posted September 20, 2014 Share Posted September 20, 2014 Im going to perform my own p3 service in the next few days but need to get hold of a few bits first. Does anyone know what size plastic tubing fits over the bleed nipple on the brakes. Do I need a syringe to get oil into the gearbox? (where could I get one from?) How much coolant do I need and can it be mixed 50/50 with distilled water? (ill be using the genuine nissan stuff) Finally does the clutch need bleeding or would it just be sufficient to syringe some fluid out and replace with new? Cheers, Liam. Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted September 20, 2014 Share Posted September 20, 2014 (edited) Yes You'll need a syringe to refill the gearbox oil, before draining though make sure you can remove the refill plug before removing the drain plug. Got my syringe from machine mart. 10 litres of coolant is what you'll need for a complete swap. The genuine nissan stuff is premixed so no need to dilute. Edited September 20, 2014 by SHEZZA 1 Quote Link to comment Share on other sites More sharing options...
liamgdr Posted September 20, 2014 Author Share Posted September 20, 2014 Ah didn't think of machine mart, damn I was hoping I could mix it, its pretty expensive for some coloured water. Any ideas on the clutch, bleed it or just replace the fluid? Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 20, 2014 Share Posted September 20, 2014 Re; the coolant. Found this on eBay. Seems a good deal but I'd just double check that it is definitely the price for 5 Litres. Link: http://www.ebay.co.uk/itm/Genuine-Nissan-L248-Premix-Engine-Coolant-Antifreeze-KE902-99945-/150939424104 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 20, 2014 Share Posted September 20, 2014 Fill the gearbox from the top using a long hose and a filler if you do not have a syringe. Best to bleed the clutch from the slave so that all the old fluid is removed. Use the genuine Nissan premix for the coolant. 5mm for the bleed hose for the brakes and slave. Alex. Quote Link to comment Share on other sites More sharing options...
liamgdr Posted September 20, 2014 Author Share Posted September 20, 2014 Re; the coolant. Found this on eBay. Seems a good deal but I'd just double check that it is definitely the price for 5 Litres. Cheers, doesn't look a bad price, as long as they send it as one package. Link: http://www.ebay.co.u...5-/150939424104 Fill the gearbox from the top using a long hose and a filler if you do not have a syringe. Best to bleed the clutch from the slave so that all the old fluid is removed. Use the genuine Nissan premix for the coolant. 5mm for the bleed hose for the brakes and slave. Alex. Cheers alex, I've never bled a clutch before, is it just the same scenario as the brakes, pump the pedal, open/close than valve, repeat etc etc Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 21, 2014 Share Posted September 21, 2014 (edited) There is a set procedure for bleeding the 350 clutch and brake hydraulics and you should find a "how to" in the guides section. Like wise for the coolant which can sometimes be a bit tricky. Alex. Edited September 21, 2014 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
