Devilz101 Posted September 16, 2014 Share Posted September 16, 2014 I'm getting my exhaust replaced because the pipework on the original one has given up (the connection of the pipes between the resonator and muffler has fallen to bits if anyones interested). Seems like a good opportunity to upgrade to a Cobra system from CougarStore. The garage doing the work have taken off my existing exhaust and said the heat shield is knackered. Anyone else had this and if so whats the best way to replace it? Thanks Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted September 16, 2014 Share Posted September 16, 2014 I'm sure you don't need it with a Cobra, But CS will advise you. Quote Link to comment Share on other sites More sharing options...
comrade Posted September 19, 2014 Share Posted September 19, 2014 If it is the Y-pipe heatshield they mean then just cut it off, every single aftermarket Y-pipe comes without it anyway. Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 19, 2014 Share Posted September 19, 2014 Heatshields aren't required on the 350. Sometimes the floor might get a little warm if you have HFC's or decats, but its nothing to worry about. Quote Link to comment Share on other sites More sharing options...
Neoncypher Posted September 20, 2014 Share Posted September 20, 2014 Can we do without the heat shield above the back box? Mine has corroded through around all four bolts and if I can get rid I will... Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 20, 2014 Share Posted September 20, 2014 What heat shield? That triangle bit stuck at the back of it? Aye, rip it off Quote Link to comment Share on other sites More sharing options...
Neoncypher Posted September 22, 2014 Share Posted September 22, 2014 (edited) Not on the back box itself (I don't have oem) I mean the flimsy bit of metal bolted to the under body of the car above the back box area.. Edited September 22, 2014 by Neoncypher Quote Link to comment Share on other sites More sharing options...
14N Posted September 22, 2014 Share Posted September 22, 2014 Not on the back box itself (I don't have oem) I mean the flimsy bit of metal bolted to the under body of the car above the back box area.. I know exactly which one you mean as mine decided to drop onto my exhaust on the M40 on the way back from the Ace Cafe. The almighty clatter it made scared the bejesus out of me! The issue was (and I'm guessing yours maybe the same) is that it had corroded around all 4 mounting points, so the flanged nuts no longer hold it in place. Give the 4 nuts a squirt of WD40, remove them (10mm socket) and then refit the heat shield with the largest washers you can find. Simples. But I do think you could also get away with removing it altogether. Just means your boot might get a bit warm. Quote Link to comment Share on other sites More sharing options...
Neoncypher Posted September 22, 2014 Share Posted September 22, 2014 Cheers 14N,t hat's exactly what's happened - my reaction was probably the same as yours! I'll give what you suggested a bash, thanks! 1 Quote Link to comment Share on other sites More sharing options...
Neoncypher Posted September 22, 2014 Share Posted September 22, 2014 (Sorry to thread-jack btw ) Quote Link to comment Share on other sites More sharing options...
14N Posted September 22, 2014 Share Posted September 22, 2014 No worries Just be careful with the 4 nuts and threaded pins they're attached to. As they're corroded they could shear quite easily. And if 3 or more of them shear, then you'll have to remove the heatsheild cos you'll have nothing to attach it to! Give them a good spray of penetrating fluid/WD40 and don't try to remove the nuts in one go. Undo them part the way, then tighten them back up a few turns, then undo them a bit further, tighten up, undo, you get the idea. Good luck! Quote Link to comment Share on other sites More sharing options...
