DoogyRev's Winter (& Sumer) Project 2014/15 Update P3
DoogyRev
As it's only going to be for display you could try an orbital sander with some 40 grit pads or even a flat block of wood with some 40 grit on. You are going to have to remove some of the metal to get the pitting out then move on to the finer stuff. I can't quite see on my phone the missing chunk but is it something that could be filled with weld and then ground to shape? When you take it for blasting I've found a few layers of duck tape will protect the machined surfaces if you are careful and watch it doesn't get under the edges.
get medieval on it's ar$e I'd start with an angle grinder and work back from there - but that's just me :lol:
as Leonk say's bad holes can be fillied with weld - I think those could be sanded out - you could always get it skimmed ;)
I use 2 layers of masking tape - it's quite surprising but the sandblaster won't go through it easily - mind you that is a home setup - the one you are going to use may be a bit more powerful :scare:
I might be having a go at a tool box this winter - See you are an inspiration (and supplier of said toolbox) ;):lol:
Edited by Keyser
  • 1 month later...
Small Update, been a while since I had a chance to get more done on the old block.
Over Christmas I got one of these . . .
It came with a whole load of tools and gizmos B) Anyway, back to the final degreasing, all them annoying little holes everywhere :angry: Now I will be getting all the crud off the bits I want to polish, mask them up and get the inside and outside ready for a good anti-rust primer.
Edited by DoogyRev
  • Like 2
Slowest table build thread ever. :stir::lol:
You can't rush a good job. All I can say is it's a good thing we don't restore engines/cars for a living. There would be non of that Hotrod, Chopper. Monkey, crazy deadline rubbish though!
Looking good Doogy!
Edited by leonk
Managed to get some more prepping done this morning, since I am doing this in stages I will prep and prime one section at a time just to stop any rust creeping in to some of the nooks and crannies.
I also came across a neat trick from a video on you tube (will look for it later) when masking up something like a block, apply tape then with a small hammer tap the tape on the edge and it will just peel away. no cutting with a knife required . . every day is a school day B)
Top and sides next :snack:
Thats all for now, thanks for looking :)
More done this evening . . .
Getting the top ready for priming
Hopefully get both sides completed tomorrow, which will leave the end that is currently fixed to the stand and the inside. I think since that not really going to be seen I will the use the remaining Truck Bed Lining I have laying about :teeth:
Got the remaining two sides done today . . just the back an the inside to do :teeth:
Thats about all I am going to have time to do for the next month as its travel time again :plane:
But at least the bits I have done won't get any more rust on :surrender: for those with a keen eye you will have spotted some pitting, this will all be revisited at a later date.
Pretty pleased how its going so far . . slow I know :stir: Rather than just paint the bulk of it black, having the polished ends and some of the bolt faces will break it up a bit B)
  • 2 months later...
Its been a while since I last updated this . . or done anything to be honest, been busy and off galavanting round the world for work. Managed to get started again this weekend
I started with more prepping, sanding & polishing, its getting there . . long way to go yet
Then started moved on to the inside, this will be sprayed next, but I have decided to polish some bits . . so more prepping :yawn:
After I stripped all the skin off my knuckles I remembered I have some other bits . . so a quick delve in the ammo box . .
I pulled out the best 5 cylinders and started degreasing a taking them apart
All stripped and degreased. The Cylinders I will take to VapourBlast for a bit of DIY cleaning, the arms I think I might polish the ends and then spray the arms . . will have to see, going to think on it for a while.
Thats all for now folks, might have some more updates next weekend. Thanks for looking :)
Edited by DoogyRev
Another little update, Thought I would make a start on cleaning up the Cylinders . . .
And whilst doing this I was pondering on fixing the glass etc . .
. . more pondering required I think.
and then this happened . . . it just snapped off your honour, :lol:
Weirdly it also happened to the other three :scare:
So I cleaned up all the rough edges
Looks like I have solved the "what to use for castors conundrum". I will start cleaning them up properly tomorrow, they should end up nice a shiney when I have finished . . just waiting for a special care package to arrive :ninja:
I have some ideas on how to support the glass, but still going to think on it for a while :shrug:
Thats all for now :wave:
Edited by DoogyRev
I decided that the feet need a little more work as top of the cylinder won't make for a stable fitting . .
So out with the grinder again
and some sanding and we have this . . .
More sanding :yawn:
And there we go :teeth: Also did a bit of prep work on the Arms (forgot to take pics)
Everything suddenly turned green :scare:
Already primed and the first top coat on . . off to do the second shortly :teeth:
:teeth:
Well they turned out ok, once my polishing ket arrives :ninja: . . they will end up a but shinier B)
I have a plan for the Glass supports . . maybe go on a reconnaissance mission tomorrow :lol:
Thats all for now peeps :wave:
Another quick update, been thinking about how to support the glass for the last few days
So I took this bit that come out originally
Poked it back in the hole from whence it came . . and fitted some rubber chair leg covers
The glass should just rest on the rubber . . I think its going to be close though :surrender:
Now going to find somewhere to weld them on :teeth: but next up will back to prepping and spraying the block B)
:wave:
Edited by DoogyRev
