High idle 2005 350z vq35de
Y23DRH
2500 rpm going down to 1100rpm
Drove the car the other day and the rpm wouldnt go lower then 2500 rpm
The car was up to running tempture aswell
I did notice if you rev the car to 3000rpm when it droped between 2500 and 2000rpm it holds for a couple of seconds then goes back down to 1100rpm
Soon as you drive and stop again 2500 down to 2000 rpm with a pause in the rev range
Then back to 1100 rpm
I have done the throttle body clean the correct way battrey off and unpluged the connections
The maf snesor is new 5 months ago but cleand maf sensor just incase
I have done the reset methods but nothing is working
Every time i change up the gears the rpm revs up insetad if dropping :/
Its bloody dangerious as almost throw the car in to another one infront of me :/
The cars off the road till its fixed any ideas what could be the problem could be ????
Any help would be appreciated ???
Edited by F4ABP
If it happened right after cleaning the Throttle body then that would probably be the issue but from my experience it doesn't seem like the symptoms of a bad TB clean, so i'm going to say start with the "free" option first and check your pipework around the intakes for a vacuum leak, see that the tubes are in place and not loose, corroded or split anywhere.
Edited by Martinjj
If you have cleaned the throttle body and changed the MAF you should perform the idle relearn procedure.
That should do the trick - unless you have a leak :)
Throttle body cleaned and new maf fitted
But still got the idle problem
Smoke test was performed and no leaks detected :/
But we did find a exhaust leak so that could be the causing it so will get that sorted and redo the idle relearn procedure
Edited by F4ABP
