Exhaust Issues!
Hougenie
Hi folks,
Took the 350z to the garage today as thought there was some corrosion of the exhaust....I was right :(
The guy at the garage tells me it's the exhaust centre and rear silencer that need replacing?!?
I am pretty clueless when it comes to this, but Ive been looking at Cobra exhaust here...
http://www.cobrasport.com/index.php/cobra-sport-exhaust-products/nissan/350z/nissan-350z-03-09/nissan-350z-centre-rear-non-resonated.html
And also Invidia Gemini exhaust system like this...
http://www.vividracing.co.uk/invidia_gemini_catback_exhaust_rolled_titanium_tips_nissan_350z_02_08_1013818816.php
My question is would these be suitable to fix the issue. I think I would go for one of these over stock if they are ok.
Sorry if this is a ridiculously simple question :surrender:
Thanks in advance.
So it seems both of these will be ok/solve the problem?
Does it just come down to which I prefer in terms of sound/look or are there any differences in performance between the 2
Thanks for the input so far
There will be imo a very slight difference in performance between the two as the Cobra is a single pipe from the Y pipe back as I understand it whereas the Invidia is a true dual exhaust system.
A true dual exhaust system is supposed to be better for performance from what I understand although I'd imagine the difference is not noticeable apart from maybe on a dyno & even then it probably isn't much.
As Stevo mentions though also depends on your budget as the Invidia is pretty much twice the price of the Cobra. ;)
I'd highly recommend the Invidia Gemini system Hougenie. It's what I bought for mine and is fantastic with no drone whatsoever.
The Cougar Store or Tarmac Sportz are both very good traders that can sort you out a good deal on your new exhaust system I'm sure. :thumbs:
+ 1 having had my invidia supplied by Tarmac and fitted by the cougar store I can highly recommend it and them too. As for budget yes the invidia is more than the cobra but it is the full cat back system so no need for a y pipe. so if you did need to change the y pipe at some point the full cobra system doesn't work out much cheaper.
Edited by SHEZZA
