D-Rage Posted September 13, 2014 Share Posted September 13, 2014 Hi, I went out this morning started the car up and the engine light came on. Decided to turn it off and see if I could do the pedal thing to read the code couldn't get this to work so gave up, the light was staying on solid and the manual said it would be fine to run. I tried to start it but it wouldn't run can't hear anything trying to start up when I turn the key. Have got a multimeter tested the battery 12.4 v and had a look at the fuses all seem to be ok, does anyone have any other ideas? Cheers matt Quote Link to comment Share on other sites More sharing options...
D-Rage Posted September 13, 2014 Author Share Posted September 13, 2014 Oh and it's a HR not sure if that will change things. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2014 Share Posted September 13, 2014 Are you sure the imobiliser hasn't kicked in? also could be a flat battery , you should be seeing about 12.8 to 13.2v on a good battery. Quote Link to comment Share on other sites More sharing options...
D-Rage Posted September 13, 2014 Author Share Posted September 13, 2014 How would I know if the immobiliser has kicked in? Quote Link to comment Share on other sites More sharing options...
Harryjax Posted September 13, 2014 Share Posted September 13, 2014 Disconnect battery for a while. Then reconnect it and see if she starts. And light goes out. Quote Link to comment Share on other sites More sharing options...
