Rear clicking noise, any other possible causes?
veeg33
Not sure my symptoms are similar to the common issue (as stated in the how to solve rear clicking discussion) but before I grease it, would be great if anyone else had similar issue that needs something else to be replaced or grease.
My observations:
No clicking when I drive off right after I started the engine.
Clicking sound only if I move off quick ish and immediately lift of my foot from the accelerator and clutch fully engaged in parallel. (hope this makes sense). After driving a good few miles (or more), if I did the same as above, I can hear the clicking noise.
Possible causes that I can think of:
1.) Rear axle - grease as suggested in the 'how to' section?
2.) Rear LSD mount/bush degraded - replacement required?
All advice is much appreciated. Hope to get all required parts and get them sorted in one go but one could argue only sort out one at a time so that you know what is the root cause. B)
My LSD mount has a leak, is this the issue?
Check your tyres too. I had a clicking noise on mine that I thought was from the rear. Turned out to be one of the steel cables in my front offside tyre.
http://www.350z-uk.com/topic/75832-unknown-noise/
Thought I had some pictures on there too but I can't find those now.
Edited by Steel Lynx
