Power Cable Routing
zebedy
Im going to run a 4-5mm Thick amplifier power cable from the battery to my new amp contained behind my passanger seat cubby hole (ive got a roadster).
So.....is there a readily available access for the cable to come through the fire wall on the passanger side. Had a quick look and cant see anything obvious there to push the cable from the engine bay into the cab.
cheers
Zeb.
Yup there is one, behind the battery right hand side there's a grommet, make a hole in this and you should end up fire wall behind the dash. You'll have to pull back the carpet, take out footwell plastics.
Then get some bathroom sealant to stop rain water getting in and around the hole you've made in the grommet.
Next to the batter and fuse box you will see the cars wiring harness. Carefully cut a slit in the rubber grommet that contains the vehicle wiring harness. The amp power cable can then be fed down into the passenger foot well. Make sure you re -seal the cut with silicon sealant to stop water seeping into the car.
great stuff. thanks. - Front speakers are being powered with just the head unit, and the amp 800w x 4 will power some large 8 x 6 mb quart componets behind the seat, cutting into the bose base speaker panel and the cubby door. Hopefully!!! lol - Ill post some pics up as Im doing it.
cheers
