Tarmac@TarmacSportz Posted September 11, 2014 Share Posted September 11, 2014 (edited) Hi All Due to lots of requests on this I have decided to do a GB for a maximum of 15 people. The Group buy will run for two weeks, and the spacers will made to order and be ready for shipment two weeks after, Payment will be required after the GB ends, please put your name down in an orderly fashion. The spacers are made from Aluminum Alloy T-6063 with T-7075 Lug nuts. Available in 5x114.3 in either 20mm or 25mm. Lightweight Alloy T-6063 construction Hubcentric spacers (Pair) Bolt on design without modification Gives a wider stance and fills the arches on your car 20mm rrp £70 per set 25mm rrp £75 per set (Pic below is of a pair of 25mm spacers) Edited September 11, 2014 by Tarmac Quote Link to comment Share on other sites More sharing options...
StevoD Posted September 11, 2014 Share Posted September 11, 2014 (edited) ? Edited September 24, 2014 by StevoD Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted September 11, 2014 Share Posted September 11, 2014 I just fitted a set of these. Absolutely perfect. :thumbs: Quote Link to comment Share on other sites More sharing options...
DanS Posted September 11, 2014 Share Posted September 11, 2014 Happy to hear your doing this, missed out on the last lot I'll put my name down, 20mm front and 25mm back is the popular choice correct? Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted September 11, 2014 Author Share Posted September 11, 2014 Happy to hear your doing this, missed out on the last lot I'll put my name down, 20mm front and 25mm back is the popular choice correct? Yup 1. DanS Quote Link to comment Share on other sites More sharing options...
pauljames90 Posted September 11, 2014 Share Posted September 11, 2014 Put me down for a set of 20mm and 25mm Quote Link to comment Share on other sites More sharing options...
PMX Posted September 11, 2014 Share Posted September 11, 2014 I'll have a set please, 20mm & 25mm Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted September 11, 2014 Share Posted September 11, 2014 1. DanS - 20mm & 25mm 2. pauljames90 - 20mm & 25mm 3. PMX - 20mm & 25mm cracking price Quote Link to comment Share on other sites More sharing options...
bc1987 Posted September 11, 2014 Share Posted September 11, 2014 What is the price? Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted September 11, 2014 Share Posted September 11, 2014 Lightweight Alloy T-6063 construction Hubcentric spacers (Pair) Bolt on design without modification Gives a wider stance and fills the arches on your car 20mm rrp £70 per set 25mm rrp £75 per set See above...!!! First Post.. Quote Link to comment Share on other sites More sharing options...
benjy88 Posted September 11, 2014 Share Posted September 11, 2014 I don't feel special anymore....... Now you definitely owe me a free sticker Chris....And some flowers. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted September 11, 2014 Author Share Posted September 11, 2014 Group buy price is £100 providing we get the numbers Quote Link to comment Share on other sites More sharing options...
bc1987 Posted September 11, 2014 Share Posted September 11, 2014 :-) that's better. I'm in Quote Link to comment Share on other sites More sharing options...
veeg33 Posted September 11, 2014 Share Posted September 11, 2014 Missed out the previous order. I suppose it's not £100 for both pairs now 😢 being tight, will the GB price go down if we fill up all 15? Quote Link to comment Share on other sites More sharing options...
veeg33 Posted September 11, 2014 Share Posted September 11, 2014 (edited) Opssss, you read my mind Tarmac! 😎 I'm in..... Add me! 20mm & 25mm Sorry, I'm not sure how to copy, paste and my name on the WANT list. (using tapatalk) Edited September 11, 2014 by veeg33 Quote Link to comment Share on other sites More sharing options...
alanm Posted September 11, 2014 Share Posted September 11, 2014 £100 .I,m in. Put me on the list for a set 20mm and 25mm,please. Quote Link to comment Share on other sites More sharing options...
ZedManTID Posted September 11, 2014 Share Posted September 11, 2014 I'll take 20mm and 25mm sets for £100. In! Quote Link to comment Share on other sites More sharing options...
Netnomad Posted September 11, 2014 Share Posted September 11, 2014 Bu**er just brought the 20mm spacers at £70 and found out the rear 25mm Eibach's I already had need a lot of messing around to fit as they have no fixed bolts. Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted September 11, 2014 Share Posted September 11, 2014 I'm in! I'll take 20mm and 25mm for £100 bargain Quote Link to comment Share on other sites More sharing options...
parello9 Posted September 11, 2014 Share Posted September 11, 2014 tarmac can you get these but with the stud pattern 5x114 to 5x120? Quote Link to comment Share on other sites More sharing options...
GasZed Posted September 12, 2014 Share Posted September 12, 2014 I'll take a set of 20mm & 25mm please Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted September 12, 2014 Share Posted September 12, 2014 Just a tip when fitting them. Use a torque wrench and torque them same as your wheel nuts. Use copper grease on the threads and put a smear around the spigot to stop it sticking, lot easier to remove, Quote Link to comment Share on other sites More sharing options...
benjy88 Posted September 12, 2014 Share Posted September 12, 2014 Or use an Airgun And then make sure they're torqued properly. I managed to fit mine all round within 15 minutes Quote Link to comment Share on other sites More sharing options...
StevoD Posted September 12, 2014 Share Posted September 12, 2014 Or use an Airgun And then make sure they're torqued properly. I managed to fit mine all round within 15 minutes Just make sure you dont over torque them with the Airgun Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted September 12, 2014 Share Posted September 12, 2014 Or use an Airgun And then make sure they're torqued properly. I managed to fit mine all round within 15 minutes Not everybody got an air gun, you can torque them equally as well with a torque wrench, most times my wheels were fitted with an air gun, they were torqued completely wrong and I had to re-do them with my torque wrench... 1 Quote Link to comment Share on other sites More sharing options...
