Kaveney Posted May 11, 2015 Author Share Posted May 11, 2015 Got some more parts coming from USA , Germany and UK She is nearly done just a few more bits but I have been saying that for a long time now . Alan Quote Link to comment Share on other sites More sharing options...
Payco Posted May 11, 2015 Share Posted May 11, 2015 (edited) Good work but is the heat tape really necessary ?. Not seen anyone else on here apply it. I think it detracts from the look of your bay. Not wanting to be negative about what you have done as it all looks good, just a question / my view.. Edited May 11, 2015 by Payco Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 11, 2015 Author Share Posted May 11, 2015 I was waiting on it looks sh*t comment I have had it on my old Mr2 Turbo and the inlet temp was 37 deg as std then 28 with the tape . Im not into looks under the bonnet so it is ok for me but I can see why people would not like the looks of it even if it does its job . Alan Quote Link to comment Share on other sites More sharing options...
Payco Posted May 11, 2015 Share Posted May 11, 2015 As I said not knocking it. I guess you are speaking to the wrong guy about looks under the bonnet. Hope to catch up with you at some point as you are in Sussex. Keep up the good work.. Quote Link to comment Share on other sites More sharing options...
Grundy Posted May 11, 2015 Share Posted May 11, 2015 Looking at Bleeding out my clutch fluid today as mine had gone the same colour as yours Any tips? Did you use a syringe to get 90% of the fluid out the engine bay fluid bottle? And what did you use on the bleed nipple to bleed out the fluid, i,e did you use a specific size pipe? Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 11, 2015 Author Share Posted May 11, 2015 As I said not knocking it. I guess you are speaking to the wrong guy about looks under the bonnet. Hope to catch up with you at some point as you are in Sussex. Keep up the good work.. I know mate I understand what you are saying and I don't think many people will be using it . Yes I am still to meet any members yet Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 11, 2015 Author Share Posted May 11, 2015 Looking at Bleeding out my clutch fluid today as mine had gone the same colour as yours Any tips? Did you use a syringe to get 90% of the fluid out the engine bay fluid bottle? And what did you use on the bleed nipple to bleed out the fluid, i,e did you use a specific size pipe? Yes I syringe out the old fluid and used a brake bleeding pipe and box . I replaced my clutch line and let too much fluid out and air in so had a task getting any pressure in to the slave Alan Quote Link to comment Share on other sites More sharing options...
hughesy Posted May 11, 2015 Share Posted May 11, 2015 Any reason why bhp had dropped as low as 225? Surely that can't be typical? Quote Link to comment Share on other sites More sharing options...
mrkieran23 Posted May 12, 2015 Share Posted May 12, 2015 I was thinking the same, 225 is far different from the factory 276, i want to get my car on the dyno at modified nationals but seeing this it was put me off in case i have a very low reading standard Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 12, 2015 Author Share Posted May 12, 2015 225 BHP is on a hub dyno so this would be around 260 - 265 BHP on a R/R dyno . Most of the 350Z DE do not make book power so 250 - 260 BHP is normal have a search . I would not get caught up with numbers its how the car drives and feels that matters . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 18, 2015 Author Share Posted May 18, 2015 Got a engine torque damper delivered form the USA on Friday Fitting was ok but space was tight . All in with earth bracket connected . There is slightly more noise / vibration in the cabin but nothing that you can feel to much . Throttle response feels a little more quicker more so in the lower gears . Alan Quote Link to comment Share on other sites More sharing options...
mouthwash Posted May 18, 2015 Share Posted May 18, 2015 Coming along nicely. Quote Link to comment Share on other sites More sharing options...
Kaveney Posted May 18, 2015 Author Share Posted May 18, 2015 Getting there only 7 more bits to go Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 1, 2015 Author Share Posted June 1, 2015 Got another job done at the weekend . Got my Ultra Racing front under brace in the post . Out an ready to fit . Installed Bolts were a pain to remove but installed well with a nice fit . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 8, 2015 Author Share Posted June 8, 2015 Few more bits done at the weekend . Motordyne copper Iso Thermal upgrade with Aramid gasket and Copper Throttle Body Heater Removed the pelnum Removed the old pressed steel gasket ( next to the Aramid gasket ) Few mill thicker All in place Then throttle body removed New Copper Throttle Body plate Installed on to throttle body All put back together and checked for leeks Alan Quote Link to comment Share on other sites More sharing options...
Ogman Posted June 8, 2015 Share Posted June 8, 2015 Looking good! Will have to let us know if you feel any improvements - be interested to see! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 9, 2015 Author Share Posted June 9, 2015 Have checked this a few times now and the plenum is tepid when before it was hot and the upper plenum / throttle body is now cold to the touch after 40 mins of driving . I wish I had done a before and after heat test on the plenum / throttle body as would be good to see the difference but it is much cooler to my surprise . Alan 1 Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 22, 2015 Author Share Posted June 22, 2015 (edited) At the weekend I got round to upgrading the suspension at last . Parts arrived from the USA . Tein springs and Tokico shocks Old shock and spring out ( this set up has done 91K miles so a bit tired ) New Blue Tokico shock Old vs new shock Old vs new spring Old vs new shock return vid http://vid298.photobucket.com/albums/mm273/kaveney_photo/WP_20150620_0091_zpsqynrvqhm.mp4 All set up new shock and spring Installed Old rear shock Old vs new New ready to go on Rear shock & spring installed Have only done a few miles but its only a little firmer than stock and should be better in the corners . Alan Edited June 22, 2015 by Kaveney 1 Quote Link to comment Share on other sites More sharing options...
Ogman Posted June 23, 2015 Share Posted June 23, 2015 Nice little upgrade. Interesting results on the last upgrades too! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 24, 2015 Author Share Posted June 24, 2015 So far the Tein / Tokico is proving a nice set up . I would say around 10 % stiffer than stock but when you push more In the corners everything tightens up . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 25, 2015 Author Share Posted June 25, 2015 Yesterday I got the car park dents on the drivers door removed that were annoying me . Small but I could see them . After All pulled out with no paint or filler so im happy with that . Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted June 26, 2015 Author Share Posted June 26, 2015 Before and after pic of the drop from the Tein springs Before After Alan Quote Link to comment Share on other sites More sharing options...
Kaveney Posted July 13, 2015 Author Share Posted July 13, 2015 Just a small update . Oil and filter change for some 5W-30 . Also installed my Gold Plug Old vs new Quote Link to comment Share on other sites More sharing options...
prometheus Posted July 13, 2015 Share Posted July 13, 2015 That's defo some good work going into it, be like a new car when your finished. Quote Link to comment Share on other sites More sharing options...
Kaveney Posted July 20, 2015 Author Share Posted July 20, 2015 Update time Was booked in to Abbey Motorsport for some work to be done . First was a new Exedy clutch and LUK DMF that was fitted and new gear box oil added . Some pic of the old units that have done 92K miles . Old DMF Old Clutch still in ok shape but some of the rivets were getting close . Then as the gearbox was off I had some DC sports S/S manifolds ( headers if you are from the USA ) installed . Old log type manifold with smallish ports and uneven length tubes . New DC Sport S/S equal length manifold Installed . And last to be re mapped on the dyno . I was told that the manifolds would only give a very small gain in power and torque so the gains are about what I was expecting with the bonus of more power and torque on the whole rev range( + 11 LB/FT at 2300 RPM ) and not moving the power and torque up all at the top of the rev range . Alan Quote Link to comment Share on other sites More sharing options...
