suspension squeek
leebottrill
I'm no expert but if it sounds as though it's originating from the back end it's probably the two drop links chirping. It's a common problem on the Z and the fix seems to be to replace them. You can get modified drop links from Clark Motorsport which apparently last a lot longer. Hope it helps
