Pipe from clutch oriface to clutch hose.
350 Russ
If it is the end that I think it is then mole grips or vice grips should do the trick, however you may have to chop off the male rounded end and fit a new one using a flaring tool.
Alex.
It's the end nearest the slave cylinder on the male fitting to the hose. I've had grips in there but it wouldn't budge and not much room in there for anything else
