.:Bullen:. Posted September 5, 2014 Share Posted September 5, 2014 Hi guys Ive just got hold of a JWT twin turbo kit from the states for cheap money. Have any of you guys fitted one or know what trouble I'm going to run in to ? Ha I know it's not going to be a direct bolt & go I'm expecting a few troubles just thought I'd ask on here. Also I'm yet to get injectors I'm running a standard block so will be low boost do you guys recommend 440 or 550cc injectors ? Appreciate any help Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 5, 2014 Share Posted September 5, 2014 You mean that you are now doing your research after you have bought the twin turbo kit ? Quote Link to comment Share on other sites More sharing options...
WINKJ Posted September 5, 2014 Share Posted September 5, 2014 You mean that you are now doing your research after you have bought the twin turbo kit ? It seems so Alex... He stated the kit was a very good price so most likely had to act fast...... Don't see the harm in that. Quote Link to comment Share on other sites More sharing options...
Keyser Posted September 5, 2014 Share Posted September 5, 2014 I don't know much about the JWT kit but 550 would be the minimum on injectors I was running 725 - also depends on power you are after, but on a stock engine you should be safe on 550 You need a built engine for best returns lower comp pistons and crank up the boost Good luck with it. 1 Quote Link to comment Share on other sites More sharing options...
.:Bullen:. Posted September 5, 2014 Author Share Posted September 5, 2014 No I've done abit of research but obviously a lot or most of it infact is from the states so wanted some uk info but as guessed the kit came up and I did have to act fast to get it. But I appreciate the advise il get some 550s, I'm not upping the internals just yet il run it on 7-8psi and upgrade the internals next year hopefully. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
evilscorp Posted September 5, 2014 Share Posted September 5, 2014 Darren is selling some 725cc injectors in the for sale section. 2 Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted September 5, 2014 Share Posted September 5, 2014 Coming from the US , are you sure it will fit at all , you may struggle to fit the kit with our steering column on the other side. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 5, 2014 Share Posted September 5, 2014 Darren is selling some 725cc injectors in the for sale section. Yes I have a full set of ID 725 cc injectors with clips & pins. http://www.350z-uk.com/topic/85406-injector-dynamics-725cc-brand-new-set-of-6-640-delivered/ Sounds like it's going to be an interesting build. where are you based? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 6, 2014 Share Posted September 6, 2014 Coming from the US , are you sure it will fit at all , you may struggle to fit the kit with our steering column on the other side. My point exactly, as research after you have purchased the product is futile. Most USA L/H/D turbo kits usually have an issue with the manifold clearing the steering column when fitted to R/H/D cars. Alex. Quote Link to comment Share on other sites More sharing options...
.:Bullen:. Posted September 6, 2014 Author Share Posted September 6, 2014 Yes I did my research and thought that would be a problem but I dont use my car as a daily driver, and I can get a custom manifold made up if need be. I know its a gamble but its a risk I took if it all fails then I will just re sell the kit on. Im not a dreamer behind a desk thinking it will be an easy fit. Im a trained mechanic and now a offshore technician so im in the right place to get it all sorted & have access to all the tools/companys i need to get it on well fingers crossed anyways :-) 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 6, 2014 Share Posted September 6, 2014 Remember that the manifold is cast. Quote Link to comment Share on other sites More sharing options...
.:Bullen:. Posted September 6, 2014 Author Share Posted September 6, 2014 I was looking at ditching the cast manifolds and hopefully getting some stainless ones designed up then it should be easy to cut & re weld the downpipes around the steering column if needs be. Plus it might give me a little extra flow to the turbos Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 6, 2014 Share Posted September 6, 2014 I was looking at ditching the cast manifolds and hopefully getting some stainless ones designed up then it should be easy to cut & re weld the downpipes around the steering column if needs be. Plus it might give me a little extra flow to the turbos Good luck with that, however unfortunately I can't see that working. Quote Link to comment Share on other sites More sharing options...
Jonny Z Posted September 6, 2014 Share Posted September 6, 2014 Bit of usfull info for the future, a nice easy way to work injector sizes/requirements out is this Take the injector size (say 550cc) and multiply it by the number of required injectors ( 6 here) now devide that by 5.5 (hp per cc of fuel) and that will give you your theoretical maximum power capabilities, this does make a few assumptions but it's the best guide for quickly specing injectors. 550*6/5.5= 600 As you can see 550cc injectors will give you plenty headroom for the future if you do decide to forge the engine Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 6, 2014 Share Posted September 6, 2014 I was looking at ditching the cast manifolds and hopefully getting some stainless ones designed up then it should be easy to cut & re weld the downpipes around the steering column if needs be. Plus it might give me a little extra flow to the turbos Good luck with that, however unfortunately I can't see that working. Why not Alex? Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 6, 2014 Share Posted September 6, 2014 I'd be interested to know how different the jwt TT kit is different to the aps kit, as the aps kit fits nicely on the rhd 350z 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 6, 2014 Share Posted September 6, 2014 APS give you the option of International, American or Australian as far as I know. Quote Link to comment Share on other sites More sharing options...
A9H-RX Posted September 6, 2014 Share Posted September 6, 2014 No I've done abit of research but obviously a lot or most of it infact is from the states so wanted some uk info but as guessed the kit came up and I did have to act fast to get it. But I appreciate the advise il get some 550s, I'm not upping the internals just yet il run it on 7-8psi and upgrade the internals next year hopefully. Sent from my iPhone using Tapatalk Bit of usfull info for the future, a nice easy way to work injector sizes/requirements out is this Take the injector size (say 550cc) and multiply it by the number of required injectors ( 6 here) now devide that by 5.5 (hp per cc of fuel) and that will give you your theoretical maximum power capabilities, this does make a few assumptions but it's the best guide for quickly specing injectors. 550*6/5.5= 600 As you can see 550cc injectors will give you plenty headroom for the future if you do decide to forge the engine I'm running 500cc injectors on my APS TT kit. Running 502bhp @ around 10psi 1 Quote Link to comment Share on other sites More sharing options...
HaydnH Posted September 11, 2014 Share Posted September 11, 2014 APS give you the option of International, American or Australian as far as I know. American = LHD, International = RHD... Australian = upside down?? 1 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 11, 2014 Share Posted September 11, 2014 will it fit RHD. Biggest problem Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 11, 2014 Share Posted September 11, 2014 will it fit RHD. Biggest problem I doubt very much if the JWT will fit a RHD motor for the reasons previously given. Quote Link to comment Share on other sites More sharing options...
A9H-RX Posted September 12, 2014 Share Posted September 12, 2014 will it fit RHD. Biggest problem I doubt very much if the JWT will fit a RHD motor for the reasons previously given. Steering rack will cause biggest problem.. Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted September 12, 2014 Share Posted September 12, 2014 I don't know much about the JWT kit but 550 would be the minimum on injectors I was running 725 - also depends on power you are after, but on a stock engine you should be safe on 550 You need a built engine for best returns lower comp pistons and crank up the boost Good luck with it. I am on the same 725 injectors but read up as they might have there own recommendations Quote Link to comment Share on other sites More sharing options...
.:Bullen:. Posted October 4, 2014 Author Share Posted October 4, 2014 Hi guys right got stuck in with the kit last night and this morning, manifolds are all off and as expected the steering rack is the sticking point! Here's a couple of pictures from what I can see my options are space out the rack, shim up the engine or have a new knuckle made although I believe gtm do this in the states or lastly get new manifolds made up. If anyone has any helpful suggestions fire away :-) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted October 4, 2014 Share Posted October 4, 2014 have you looked at octets build thread, he had the same issue, iirc he altered the rack by the uj Quote Link to comment Share on other sites More sharing options...
