compression test
alexdax
first 2 were just testing the machine. ;)
I think you misunderstand, I meant if you add a small amount of oil to each cylinder, and conduct the test again you could end up with a different reading because oil will help ring seal, so if its a bad valve seal the reading for those cylinders will remain low.
ok i get it now..
yep i could do it next time
:thumbs:
