StevoD Posted September 3, 2014 Share Posted September 3, 2014 I did get offered a wrap from a company in Northampton for 950 but I passed as didn't want it at the time Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 3, 2014 Share Posted September 3, 2014 One word of caution regarding wraps ~ me & my mate who used to run a catering business together had our large Iveco van wrapped to help with advertising. The wrap looked great but unfortunately the company that did it made a few mistakes when doing it. When cutting the wrap to fit around edges/doors etc they cut too deep with their scalpels and even went through the paint down to primer & even bear metal in a few places. Obviously we complained once we noticed this and some of this had to be rectified at their cost using a "chips away" type person who they sourced to spray paint areas of the van where they had gone through the paint. Unfortunately we found more areas they had cut into years later when the business was closed for business & the wrap removed completely. Some areas had even started to rust slightly so it did effect the re-sale value of our van. Just fyi. Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 3, 2014 Share Posted September 3, 2014 On 03/09/2014 at 22:05, GMballistic said: One word of caution regarding wraps ~ me & my mate who used to run a catering business together had our large Iveco van wrapped to help with advertising. The wrap looked great but unfortunately the company that did it made a few mistakes when doing it. When cutting the wrap to fit around edges/doors etc they cut too deep with their scalpels and even went through the paint down to primer & even bear metal in a few places. Obviously we complained once we noticed this and some of this had to be rectified at their cost using a "chips away" type person who they sourced to spray paint areas of the van where they had gone through the paint. Unfortunately we found more areas they had cut into years later when the business was closed for business & the wrap removed completely. Some areas had even started to rust slightly so it did effect the re-sale value of our van. Just fyi. This is what worries me the most. It's very very simple to cut vinyl, no more than the weight of the craft knife itself is needed, however you hear many stories about people damaging the vehicle because of cutting too hard. About the £950 wrap, surely that doesn't include materials and/or VAT? Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted September 3, 2014 Share Posted September 3, 2014 Make sure they use cast wrap not just signwriting vinyl like a lot of companies do, that's what causes a wrap to bubble and lift a couple of months down the line as it tries to flatten itself out again instead of staying with the shapes of the car. There's a reason a wrap isn't cheap Quote Link to comment Share on other sites More sharing options...
JoKeR Posted September 3, 2014 Author Share Posted September 3, 2014 I've been to him for previous work so I think that's why it's a good price like I said I have seen a wrap his blokes done and I genuinely thought it was paint! Thanks for all ur advice people. I've got a few areas to prep before hand so in a few months I'll be getting this done as I'm not made of money lol but back to colour choice; matte orange?? That's what she 'Zed' :-/ Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted September 4, 2014 Share Posted September 4, 2014 Not bad, not bad! 2 Quote Link to comment Share on other sites More sharing options...
StevoD Posted September 4, 2014 Share Posted September 4, 2014 Plastidip an option? 1 Quote Link to comment Share on other sites More sharing options...
Payco Posted September 4, 2014 Share Posted September 4, 2014 Good luck but at that price I really fear for you and in particular what it will look like in a years time... Quote Link to comment Share on other sites More sharing options...
zippypooz Posted September 4, 2014 Share Posted September 4, 2014 Just thought id butt in!! Firstly i wouldnt let ANYONE wrap my Zed for 950.00, a good wrap, no cutting on the car, decent vinyls (i recommend Avery, better than 3m and Hexis) and 3 days work will cost you between 1700-2000. No less. As for prepping the car, bodywork should be in tip top condition, no cheap spray jobs or youre gonna lose your paint and usually it will take around 4/5 hours to get clean and degreased. As AliveBoy rightly says, only use bubblefree wrapping vinyls, not standard, although even bubblefree will fail just as quick as a normal vinyl if it isnt post heated. It has 2 memories, 1 as it comes and 2 after you have applied it to your car. Once you heat it to the correct temperature it forgets the first memory and conforms to its latter shape. Lights, door handles etc etc should all come out too...if not, then theyre cutting on the car. Obviously its up to you what you do, but i do it for a living, i get fed up with hearing all the negative stories about car wrapping...its a great way to mod your car if you want it...its just a shame there are people out there that think its easy and anyone can do it, when really they have no clue as to its strengths and weaknesses, its application and its limitations. Good luck whatever you decide to do. 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 4, 2014 Share Posted September 4, 2014 On 04/09/2014 at 17:15, zippypooz said: Just thought id butt in!! Firstly i wouldnt let ANYONE wrap my Zed for 950.00, a good wrap, no cutting on the car, decent vinyls (i recommend Avery, better than 3m and Hexis) and 3 days work will cost you between 1700-2000. No less. As for prepping the car, bodywork should be in tip top condition, no cheap spray jobs or youre gonna lose your paint and usually it will take around 4/5 hours to get clean and degreased. As AliveBoy rightly says, only use bubblefree wrapping vinyls, not standard, although even bubblefree will fail just as quick as a normal vinyl if it isnt post heated. It has 2 memories, 1 as it comes and 2 after you have applied it to your car. Once you heat it to the correct temperature it forgets the first memory and conforms to its latter shape. Lights, door handles etc etc should all come out too...if not, then theyre cutting on the car. Obviously its up to you what you do, but i do it for a living, i get fed up with hearing all the negative stories about car wrapping...its a great way to mod your car if you want it...its just a shame there are people out there that think its easy and anyone can do it, when really they have no clue as to its strengths and weaknesses, its application and its limitations. Good luck whatever you decide to do. Like anything, worth doing properly or not at all, just out of interest how much would you say a decent vinyl wrap material would cost for a Zed? Maybe the £950 was just to spray, prep,& wrap the bonnet & roof 1 Quote Link to comment Share on other sites More sharing options...
zippypooz Posted September 4, 2014 Share Posted September 4, 2014 (edited) On 04/09/2014 at 17:34, spursmaddave said: On 04/09/2014 at 17:15, zippypooz said: Just thought id butt in!! Firstly i wouldnt let ANYONE wrap my Zed for 950.00, a good wrap, no cutting on the car, decent vinyls (i recommend Avery, better than 3m and Hexis) and 3 days work will cost you between 1700-2000. No less. As for prepping the car, bodywork should be in tip top condition, no cheap spray jobs or youre gonna lose your paint and usually it will take around 4/5 hours to get clean and degreased. As AliveBoy rightly says, only use bubblefree wrapping vinyls, not standard, although even bubblefree will fail just as quick as a normal vinyl if it isnt post heated. It has 2 memories, 1 as it comes and 2 after you have applied it to your car. Once you heat it to the correct temperature it forgets the first memory and conforms to its latter shape. Lights, door handles etc etc should all come out too...if not, then theyre cutting on the car. Obviously its up to you what you do, but i do it for a living, i get fed up with hearing all the negative stories about car wrapping...its a great way to mod your car if you want it...its just a shame there are people out there that think its easy and anyone can do it, when really they have no clue as to its strengths and weaknesses, its application and its limitations. Good luck whatever you decide to do. Like anything, worth doing properly or not at all, just out of interest how much would you say a decent vinyl wrap material would cost for a Zed? Maybe the £950 was just to spray, prep,& wrap the bonnet & roof Wrapping material can cost around 20 to 35 quid a metre, id only use Avery Supreme these days, 3m and Hexis are reasonably good but nowhere near Avery. Bulletmagnets roof was done in Avery. Edited September 4, 2014 by zippypooz Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 4, 2014 Share Posted September 4, 2014 On 04/09/2014 at 17:40, zippypooz said: On 04/09/2014 at 17:34, spursmaddave said: On 04/09/2014 at 17:15, zippypooz said: Just thought id butt in!! Firstly i wouldnt let ANYONE wrap my Zed for 950.00, a good wrap, no cutting on the car, decent vinyls (i recommend Avery, better than 3m and Hexis) and 3 days work will cost you between 1700-2000. No less. As for prepping the car, bodywork should be in tip top condition, no cheap spray jobs or youre gonna lose your paint and usually it will take around 4/5 hours to get clean and degreased. As AliveBoy rightly says, only use bubblefree wrapping vinyls, not standard, although even bubblefree will fail just as quick as a normal vinyl if it isnt post heated. It has 2 memories, 1 as it comes and 2 after you have applied it to your car. Once you heat it to the correct temperature it forgets the first memory and conforms to its latter shape. Lights, door handles etc etc should all come out too...if not, then theyre cutting on the car. Obviously its up to you what you do, but i do it for a living, i get fed up with hearing all the negative stories about car wrapping...its a great way to mod your car if you want it...its just a shame there are people out there that think its easy and anyone can do it, when really they have no clue as to its strengths and weaknesses, its application and its limitations. Good luck whatever you decide to do. Like anything, worth doing properly or not at all, just out of interest how much would you say a decent vinyl wrap material would cost for a Zed? Maybe the £950 was just to spray, prep,& wrap the bonnet & roof Wrapping material can cost around 20 to 35 quid a metre, id only use Avery Supreme these days, 3m and Hexis are reasonably good but nowhere near Avery. Bulletmagnets roof was done in Avery. I've only used 3M and Hexis and done small items, but if you say Avery and BM likes it too then that is good enough for me 1 Quote Link to comment Share on other sites More sharing options...
StevoD Posted September 4, 2014 Share Posted September 4, 2014 Is it safe to put stickers on a vinyl wrapped panel ? Quote Link to comment Share on other sites More sharing options...
zippypooz Posted September 4, 2014 Share Posted September 4, 2014 On 04/09/2014 at 20:15, StevoD said: Is it safe to put stickers on a vinyl wrapped panel ? Personally i wouldnt as it can lift the wrap if you ever want to remove them...its happened to me before. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted September 4, 2014 Share Posted September 4, 2014 Put stickers under the vinyl and "ghost" Not serious and Steve (zippypooz) knows I'm not Quote Link to comment Share on other sites More sharing options...
zippypooz Posted September 4, 2014 Share Posted September 4, 2014 On 04/09/2014 at 21:28, BulletMagnet said: Put stickers under the vinyl and "ghost" Not serious and Steve (zippypooz) knows I'm not Hahaha actually ive seen that done, it actually looks very effective!! Im sure youre being serious!! 1 Quote Link to comment Share on other sites More sharing options...
JoKeR Posted September 4, 2014 Author Share Posted September 4, 2014 Thanks for all your help I'll look into it a lot more and I've taken all your advice into consideration! But when I do I imagine Matte orange will be the one lol that pic made my mind up!!! That's what she 'Zed' :-/ Quote Link to comment Share on other sites More sharing options...
Neilp Posted September 4, 2014 Share Posted September 4, 2014 On 03/09/2014 at 08:59, StevoD said: On 03/09/2014 at 08:55, KyleR said: Yup, I believe there are currently ZERO purple zeds in the UK is the ex-sumo powers one still purple or has it changed now This was ZMANALEX's old car btw Quote Link to comment Share on other sites More sharing options...
Neilp Posted September 4, 2014 Share Posted September 4, 2014 On 04/09/2014 at 22:17, Neilp said: On 03/09/2014 at 08:59, StevoD said: On 03/09/2014 at 08:55, KyleR said: Yup, I believe there are currently ZERO purple zeds in the UK is the ex-sumo powers one still purple or has it changed now This was ZMANALEX's old car btw or should I say one of them... Quote Link to comment Share on other sites More sharing options...
StevoD Posted September 4, 2014 Share Posted September 4, 2014 did he work for sumo power? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 5, 2014 Share Posted September 5, 2014 On 04/09/2014 at 21:28, BulletMagnet said: Put stickers under the vinyl and "ghost" Not serious and Steve (zippypooz) knows I'm not Just draw the decals on with dry wipe then rub them off when your fed up with them 1 Quote Link to comment Share on other sites More sharing options...
Flex Posted September 5, 2014 Share Posted September 5, 2014 On 03/09/2014 at 20:05, spursmaddave said: I serious doubt you could get a bubble wrap for £950 even at mates rates You'd have fun popping it everytime you went out to your car though Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 5, 2014 Share Posted September 5, 2014 On 05/09/2014 at 07:28, Flex said: On 03/09/2014 at 20:05, spursmaddave said: I serious doubt you could get a bubble wrap for £950 even at mates rates You'd have fun popping it everytime you went out to your car though But think of all the car park dings you woukd avoid Quote Link to comment Share on other sites More sharing options...
Flex Posted September 5, 2014 Share Posted September 5, 2014 On 05/09/2014 at 07:44, spursmaddave said: On 05/09/2014 at 07:28, Flex said: On 03/09/2014 at 20:05, spursmaddave said: I serious doubt you could get a bubble wrap for £950 even at mates rates You'd have fun popping it everytime you went out to your car though But think of all the car park dings you woukd avoid Oh I think we should take this to market asap!! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 5, 2014 Share Posted September 5, 2014 On 05/09/2014 at 08:00, Flex said: On 05/09/2014 at 07:44, spursmaddave said: On 05/09/2014 at 07:28, Flex said: On 03/09/2014 at 20:05, spursmaddave said: I serious doubt you could get a bubble wrap for £950 even at mates rates You'd have fun popping it everytime you went out to your car though But think of all the car park dings you woukd avoid Oh I think we should take this to market asap!! Bugger off I'm going on Dragon's Den with it £250k for 2.5% of my business..... No I don't have a business plan or projection Peter, just 'show me the money!' 1 Quote Link to comment Share on other sites More sharing options...
