lowering springs or maybe coilovers.
r111nxx
hi all i had the above springs tein on mine when i bought it and they just don't sit that low so changed them out for some eibach pro kit springs and sits a lot lower pic below excuse my friend in the photo lol
Edited by smartme
It all depends on what you want to do.
I myself just wanted a mild drop without the need to get all the other stuff, so went Tein S-Tech route
With coilovers you of course have the freedom to lower to what you want, but same applies as above when you go lower than 20mm.
The advantage of getting coilovers I can see is that if your OEM shocks are starting to get tired and need replacing at some point, then coilovers would take care of two things in one go.
Mines lowered 20mm on Tein S springs and it's low enough to look and handle right and still deal with speed humps.Only my opinion but for what its worth Tein should be fine for the job..
Edited by Payco
