Ceejay29 Posted August 30, 2014 Share Posted August 30, 2014 Hi Jez, I purchased the DE spacer kit from you a fair while ago now. Since replacing the OEM strut brace with an aftermarket one I have noticed that it now fouls the U/S of the bonnet. I think the answer is to reduce the height of each alloy spacer you provided in your kit, thus reducing the height of the brace. Ideally I would replace them or I can try to grind them down (however this may not be accurate). My question to you is; Do you know the height of the alloy strut spacers you provide in your kit and do you have any idea where I could find replacements? Apologies the car is in the garage so I cannot pop out to measure myself. Thanks CJ Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 30, 2014 Share Posted August 30, 2014 It's the same as the spacer 5/16, well mine are. You could reduce the height of the aluminium spacers for the strut. Sand them down maybe. I can sell you a pack of aluminium spacers if needed. Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted August 31, 2014 Author Share Posted August 31, 2014 (edited) I am tempted to sand them down although trying to get all eight exact will be tough. The spacers you have; are they smaller in height? Or would they be to replace the ones I am sanding if it foreseeably c0ck it up Edited August 31, 2014 by Ceejay29 Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted August 31, 2014 Share Posted August 31, 2014 The spacers are 8mm thick, which is about the same as 5/16". You could sand them down or use stacks of M10 washers. 1 Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted August 31, 2014 Author Share Posted August 31, 2014 Thanks for your reply Jez, I think I will attempt the washers first as that seems pretty fool proof Quote Link to comment Share on other sites More sharing options...
