Gudzy Posted August 28, 2014 Share Posted August 28, 2014 I've noticed what looks like oil on my exhaust near to a bush at the rear near side, just wondering if its possible to get a replacement bush and what the part number is? Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted August 28, 2014 Share Posted August 28, 2014 You will find it here. http://nissan4u.com/parts/350z/ Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 28, 2014 Share Posted August 28, 2014 (edited) Not what I was expecting a picture of You can get uprated ones for the rear spring carrier EDIT - Just in case I misunderstood - you won't get oil out of that bush - the diff may be but not the bush Edited August 28, 2014 by Keyser 2 Quote Link to comment Share on other sites More sharing options...
hensh65 Posted August 28, 2014 Share Posted August 28, 2014 Not what I was expecting a picture of You can get uprated ones for the rear spring carrier EDIT - Just in case I misunderstood - you won't get oil out of that bush - the diff may be but not the bush That how you created the beast Keyser? using the oil from your diff everywhere Buster give a hand? Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 28, 2014 Share Posted August 28, 2014 I wash in diff oil Well I had a nice wash in gearbox oil when DarrenB came by to change his clutch - he poured it all over me I'm sure he did it on purpose as well Quote Link to comment Share on other sites More sharing options...
Gudzy Posted August 28, 2014 Author Share Posted August 28, 2014 (edited) Cheers Chris, perhaps its just oil from a diff oil change I had done a year or 2 ago in that case then. I've got a wheel wobble when cornering hard and which can also be felt over bumps, so a suspension bush having worn would seem to make sense to me. Need to take it to the garage to get it up on a lift and have a nosey I think. Edited August 28, 2014 by Gudzy Quote Link to comment Share on other sites More sharing options...
marzman Posted August 28, 2014 Share Posted August 28, 2014 That looks like copper grease to me. Quote Link to comment Share on other sites More sharing options...
Gudzy Posted August 28, 2014 Author Share Posted August 28, 2014 That looks like copper grease to me. I've not got a very good photo of it, the car is still on the floor. I was referring to the bush behind the screw which is covered in copper grease. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted August 28, 2014 Share Posted August 28, 2014 Not what I was expecting a picture of George maybe? 1 Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 28, 2014 Share Posted August 28, 2014 Damn, thought I had some interesting moderation to do 2 Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 28, 2014 Share Posted August 28, 2014 @ Toon Chris - Errr No not George @ Ebized - I was hoping to get a look before you did Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 28, 2014 Share Posted August 28, 2014 @ Gudzy - It is possible that the heat from the zorst is getting the grease hot enough to drip on the Zorst - give it a clean and see if it comes back. If you have wheel wobble then defo get it on a ramp could be bearing or a bush - if it is wallow or a slight rocking when turning in hard I would also be looking at the shocks may be warn or failed (they can also leak oil) Just a few things for you to consider, hope it helps Quote Link to comment Share on other sites More sharing options...
