Help needed choosing a garage to get my clutch fitted
leet8845
I've brought my parts and I'm having my flywheel, clutch,spigot bearing, slave cylinder and clutch line changed. I've spoke to the mechanic at a local company, a1-clutches.co.uk and said they would be able to fit everything.
They said they have done 350zs before but I just want to know if there's anything particularly difficult about the job that would mean I'm better off taking it to 350z specialist?
Ok I will do, how do they know which way is which? It's a LUK flywheel.
Not 100% sure but I think one of the holes in the flywheel is a smaller diameter and this fits onto a locating pin, maybe someone else can clear this up for you though ...
I did consider cougar store but this other place is a 10 minute drive and if it's a standard job that a clutch specialist can handle then I'd rather not have to travel and spend a day there.
My next mods however will be different, I want a pipercross induction kit, plenum spacer, high flow cats and a UpRev remap. I think I'll travel to Horsham Developments for those.
I agree but that's why asked here first. If it was something more Z specific, I wouldn't hesitate but you'd think a clutch specialist should be able to fit a clutch without messing it up.
Anyway, I got the car back today. The new clutch feels great, low biting point and loads of grip. Just super smooth. I would recommend a1-clutches. Fitted flywheel, clutch, slave, clutch line and molyslip for £250 and threw in some brake fluid.
