SJ350z Posted August 21, 2014 Share Posted August 21, 2014 Well I cant do this for shiiettt... got mulgrips on the bottom and had pliers on the top but was going to mark it so tried to my hand and it os not budging. There's like no space so its quite awkward as it is! Any ideas ?? Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted August 21, 2014 Share Posted August 21, 2014 (edited) mine just twisted off with a bit of brute force! i didnt need to hold anything with mole grips Edited August 21, 2014 by -Bradders- Quote Link to comment Share on other sites More sharing options...
coldel Posted August 21, 2014 Share Posted August 21, 2014 Best to put the molegrips on the base as you can twist the shaft and damage the gearing if you do not secure it. Quote Link to comment Share on other sites More sharing options...
SJ350z Posted August 21, 2014 Author Share Posted August 21, 2014 Alright Hercules lol. Gonna have a few more tries at this. The guide on here sais take the ac unit up and grip the bottom lol Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted August 21, 2014 Share Posted August 21, 2014 maybe thats why my gearbox feels nackered lol 1 Quote Link to comment Share on other sites More sharing options...
SJ350z Posted August 21, 2014 Author Share Posted August 21, 2014 Ok its not budging at all going to have to borrow some tools off a friend. Such a pain in the a$$ lol Quote Link to comment Share on other sites More sharing options...
Grundy Posted August 21, 2014 Share Posted August 21, 2014 Hmmm... when I did mine, lifted up the plastic around the gaitor. Grapped the shaft which is covered in 'cotton wool' then just twisted the top. I can't remember but do these screw opposite way? Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted August 21, 2014 Share Posted August 21, 2014 I had to use a pair of grips on the shaft below the gear knob and got a pal to force the gear knob round from the passenger side as I couldn't get enough leverage on my own too much lock tight from the factory maybe, was extremely difficult to remove and unfortunately the oem gear knob was destroyed during removal but was well worth the effort as my replacement is great. I think there is a how to on here somewhere which describes using 2 pairs of grips, be careful not to twist the shaft as may cause damage, good luck Quote Link to comment Share on other sites More sharing options...
SJ350z Posted August 21, 2014 Author Share Posted August 21, 2014 Yeah I checked the guide and cant get the leverage. Pliers are useless and I'm not strong enough using my left arm. Don't want to damage anything so have to be careful lol Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted August 21, 2014 Share Posted August 21, 2014 When i did the guide and removed the knob i found that it had been loctited into place hence could be a little tight. Quote Link to comment Share on other sites More sharing options...
SJ350z Posted August 21, 2014 Author Share Posted August 21, 2014 :angry: Loctite is strong stuff lol. Will give this another go at the weekend. I know whats going to happen.. I'll get it off.. and my new knob wont fit Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted August 21, 2014 Share Posted August 21, 2014 (edited) :angry: Loctite is strong stuff lol. Will give this another go at the weekend. I know whats going to happen.. I'll get it off.. and my new knob wont fit How many times have you swore at it so far, I did the air was blue with mine Edited August 21, 2014 by tatooandy67 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 21, 2014 Share Posted August 21, 2014 If the methods as described above do not work for you then just remove the bolt and nut from the gear shift linkage and remove from the car the complete shifter. Then just clamp it in a vice and screw off the the shift knob. Alex. Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted August 21, 2014 Share Posted August 21, 2014 (edited) Try tightening it, that can sometimes break the seal if it has been put on with Loctite or by a Sumo wrestler who happened to be passing the build line. I had to use two BIG BIG grips on mine and it did destroy the leather but as I was replacing it I didn't mind. David Edited August 21, 2014 by Tinyflier Quote Link to comment Share on other sites More sharing options...
GMballistic Posted August 21, 2014 Share Posted August 21, 2014 Sounds like you're doing everything right SJ but just in case here's the guide for you; http://www.350z-uk.com/topic/80722-gear-knob-removal/ Quote Link to comment Share on other sites More sharing options...
