hard acceleration (high rpm) voltage dropping down
Sabo
Hi everyone,
I have 2006 350z (130000km)
recently I have voltage problem
When I make a hard acceleration,my alternator is failing down and stop working at the same time hand brake and battery lights on.
1 week ago I went to the Nissan service, technical service 4 days tried to find out what caused the failure.
finally yesterday they called me and told me the name of the problematic part.
The name of the broken part is Solenoid Valve.
technical service said dysfunctional parts need to be replaced than I said ok, change it
and they replaced to part, they put the new one and I took my car today, and I've tested but but nothing has changed
everything is same :(
I immediately called the person in charge and he said come back again :)
I do not want to go there again
What do you think causes the problem.
Please help me guys
They said alternator and battery working fine also all cables all connections are fine
what else??
Thanks
agreed the voltage should go up under hard acceleration, since the alternator is belt driven and the belt will be driving it faster. might be an idea to check the state of the auxillary belts and that they're all nice and tight, and check the alternator bearings aren't seized or anything.
normal driving voltage is 14-15v
when I change the gear in high RPM 3 or 4 times my voltage goes down around 12v.
I think the alternator stops only the battery voltage stays.
that time car using only battery voltage
after the normal driving alternator suddenly coming back and voltage increasing to 14v again.
