Zhorno Posted August 20, 2014 Share Posted August 20, 2014 When my car is cold it's started making a noise when I turn the wheel , reasonably loud , I'm guessing like the power steering pump or somthing ? I'll try get a video Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 20, 2014 Share Posted August 20, 2014 (edited) Check belt tension and PAS fluid level for starters. Pumps in stock if required. Alex. Edited August 20, 2014 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Zhorno Posted August 20, 2014 Author Share Posted August 20, 2014 How would I know how tight the belt needs to be ? , it has a little squeak to it when I go on the throttle aswell ( I was told that could be the belt ) only little , how much is a pump either way ? And how hard isit to do ? Big job? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted August 20, 2014 Share Posted August 20, 2014 My old 200SX S14 used to squeal like a bitch when it was damp on autumn mornings.I just tightened it up a few mil at a time until it stopped. Have you had a look in the FSM pdf's online for the belt tension free play? Quote Link to comment Share on other sites More sharing options...
Zhorno Posted August 20, 2014 Author Share Posted August 20, 2014 Fsm ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
