Best decision I've ever made!
Welcome to the club. I'm new myself :)
As for UpRev ...
Better throttle response - the standard ECU reduces throttle response in the lower gears. By tuning the throttle pedal to throttle plate map we can make the car feel more lively. Also, fuel and ignition timing map optimisation is carried out leading to further improvements
Doesn't the ECU limit 1st gear to 60% throttle, 2nd to 75% and third to 80%? This is the main reason I'm thinking of an UpRev.
Welcome along mate. Nice looking car you've got there. Did you do the wheels and door handles yourself?
Thanks! They were done by the previous owner... The wheels are mint but the handles could do with re-doing... :-)
Job 1... Replacement headlights! They are a bit misty on the inside! :-/ anyone got a solution for this... Or a recommendation on which to buy? :-/
Dan
Dan
Are you sure it's on the inside?
Headlights misting/hazing up is a common problem on the Zeds and it's usually on the outside due to UV damage. I recently restored my headlights using a Meguiars headlight restoration kit from eBay that was around £17 delivered.
Has made a great difference and I tried to protect it using Turtle wax Ice synthetic paste afterwards as a UV protector although it does seem to be coming back slightly. Will buy a proper UV sealant from GTechniq soon and that should protect them properly then.
Link: http://www.350z-uk.com/topic/88783-headlight-restored/
:thumbs:
