Daryl Posted August 13, 2014 Share Posted August 13, 2014 Just wondering if its possible to get a rubber gasket for the upper plenum to lower plenum. Basically, i have a Kinetix V plenum which i got 2nd hand, and iv spent some time modifying it. However, as it was 2nd hand, it did not have the cork gasket that should come with it. I saw a post on a US site which says the guy ditched the cork gasket and got a rubber one. However, I cant seem to find a rubber one anywhere. I dont want to fit the plenum with just some gasket gunk, as I wouldnt trust that seal. However, if thats the way it has to be, then so be it. If all else fails, i may make my own from a sheet of rubber at work. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 13, 2014 Share Posted August 13, 2014 If you are referring to plenum to inlet manifold, then you must fit a gasket, either oem or Iso Thermal Aramid. Alex. Quote Link to comment Share on other sites More sharing options...
Daryl Posted August 13, 2014 Author Share Posted August 13, 2014 Cheers Alex,am i right in thing the standard gasket is the metal one? Where can i find a Aramid one? Quote Link to comment Share on other sites More sharing options...
