Diff Fluid Question??
350zedd
Have been using the specified Nissan diff fluid as recommended by traders on here Part No.KE907-99932
On the back of the 1L container it states:
"Nissan genuine differential fluid formulated and approved for Nissan differential gear vehicles.
Not to be used when a Nissan genuine LSD fluid is required."
When is genuine LSD fluid required?
Can someone please explain the last bit as I'm a bit confused
Simples, genuine LSD fluid is required when you run a genuine Nissan LSD.
I am assuming you have a UK car with a Viscos diff which is not a genuine LSD
Alex.
Ok Alex its a 57 HR, if its a viscous diff I assume it uses something like silicon oil which is in a sealed unit and cant be changed. The rest of it is like an open diff, hence the standard oil used.
Am I correct in thinking this?
