iLott Posted August 10, 2014 Share Posted August 10, 2014 Afternoon chaps, my Z in the last couple of days has been having battery issues. If I leave the car for a few hours 2/3 upwards, the battery drains and the car will have a lot of trouble starting or just won't crank over at all. My voltage gauge reads just under 14volts when running and doesn't move with revs, and I've tested it with a voltmeter too and it reads about 13.98 on idle and 14.2 when revving up to about 3k rpm. My friend seems to think the alternator is overcharging the battery, but ever since I remember it's been reading around 14volts when on. Just want some knowledge dropping on my ass and to see if somebody else has had the same problem/ experience. Cheers! Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted August 10, 2014 Share Posted August 10, 2014 Did you install something new recently? Quote Link to comment Share on other sites More sharing options...
iLott Posted August 10, 2014 Author Share Posted August 10, 2014 Nope nothing new on the car since the body mods and they were months and months ago! That's why this is puzzling me because it's just all of a sudden Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 10, 2014 Share Posted August 10, 2014 How old is the battery ? Quote Link to comment Share on other sites More sharing options...
iLott Posted August 10, 2014 Author Share Posted August 10, 2014 No idea, it's been on there since I bought the car April 2013. Does anyone know what voltage the alternator should be putting out? Quote Link to comment Share on other sites More sharing options...
350zedd Posted August 10, 2014 Share Posted August 10, 2014 Alternator will be putting out about 14 volts. It would be overcharging at 15-16 volts. Battery could be on its last legs and not holding its charge OR something could be draining it. You would have to pull one of the battery leads off and put an ammeter in series (or a multimeter set to amps) to check if its pulling any significant current with everything switched off. If you find that it is, then you would have to pull fuses one at a time to identify which circuit is causing the drain. Quote Link to comment Share on other sites More sharing options...
iLott Posted August 10, 2014 Author Share Posted August 10, 2014 I've disconnected it tonight so if it's healthy tomorrow I know that something is draining it. Then I'll do what you suggested with pulling fuses. I really hope it's just battery and I can pop along to halfords tomorrow and get one. How easy is it to change out a battery on the Z's? It looks pretty awkward... Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted August 10, 2014 Share Posted August 10, 2014 Just pull the surrounding trim off disconnect and out it comes. 1 Quote Link to comment Share on other sites More sharing options...
choptop Posted August 11, 2014 Share Posted August 11, 2014 Get a Bosch battery at Eurocarparts if you do need to change it. Cheaper than Halfords for a quality battery. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted August 11, 2014 Share Posted August 11, 2014 In the good old days wasn't this just called a flat battery,because its dead? 1 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 11, 2014 Share Posted August 11, 2014 In the good old days wasn't this just called a flat battery,because its dead? Quote Link to comment Share on other sites More sharing options...
350zedd Posted August 11, 2014 Share Posted August 11, 2014 In the good old days wasn't this just called a flat battery,because its dead? Hey... why didnt I say that instead of babbling on! Quote Link to comment Share on other sites More sharing options...
ts743 Posted August 11, 2014 Share Posted August 11, 2014 My battery died without much warning at all this week. Lasted a day after a charge and then I charged it all night to find it wouldn't even turn the engine over in the morning. Grabbed a Bosch battery with 4yr guarantee from Euro Car Parts. Be aware that they have it listed on eBay for £10 cheaper and you can buy and collect locally (currently no voucher codes being accepted on their website and Car Parts 4 Less are more expensive in this instance). Quote Link to comment Share on other sites More sharing options...
